Waterless coolant.
Discussion in 'Mods, Upgrades, Accessories and Products' started by lee711, Oct 18, 2012.
  1. lee711
    lee711 Active Member
    I was watching a prog on discovery the other night and the mechanic replaced the engine coolant on a car with waterless coolant. It doesn't boil till 190'c , it doesn't expand as it heats up ( he proved this by removing the rad cap on an engine that was up to temp and it didn't overflow or spray in his face ) and prevents corrosion in the cooling system. You need to purge the system with a prep flush to remove all remnants of H2O before converting to this fluid and he said it was also a lifetime product ie . never needs replacing.
    The bad bit is it's not cheap but hey it'll last a lifetime.
    Details here - About Evans Waterless Engine Coolants
    - http://www.evanscooling.com/assets/pdfs/HighPerformanceCoolantFlyer.pdf
    - Evans Power Cool for Track and Trail Motorbikes, Moto X, Enduro and Quads
    - Evans Prep Fluid for Radiator and System water removal
    What do you think ??
  2. Si.
    I use water wetter as a matter of course...sounds similar?
  3. raphael
    raphael Elite Member
    i watched that aswell! got to be worth a look
  4. Remal
    watched that today, good old wheeler dealers. I was interested in the coolant as well
    I even got Mike on my FB
  5. thezipsteruk
    thezipsteruk Elite Member
    lol its funny how these poor guys resurrect an old classic car with love affection and hard work ....
    ..but we all get moist over the coolant pmsl
    add me to the sad (but v interested) list lol
  6. Remal
    Just sent Mike a message to ask if it was the Evans stuff Ed used
  7. Nutty Tart
    Nutty Tart Well-Known Member
    Well spotted Lee ....... I like the look of that
  8. CastrolCraig
    CastrolCraig Active Member
    I use the Evans waterless coolant at the mo, UK distributor is Racebikebitz, very good stuff.
  9. r1monkey
    r1monkey Active Member
    a bit expensive to replace if you were to get a split hose or water pump leak.
