Ok wired it all up double checked everything twice wont start ... took it off and plugged it back it without loom starts ... did it again with hm loom wont start ... whats the problem ? Looks like the looms faulty i guess it says in the instructions The sub loom are labeled yk sh etc it is very important that only the correct loom is used otherwise the bike wont start
the loom should be labelled h/s for honda/suzuki. If you have the loom still on, unplug the quickshifter and bridge the connector to rule out the qs itself.
Double check you have the right loom first, bridge the loom first to make sure it’s not the loom, and double check you have a good earth as that can cause it to play up when it’s all connected
