What are these two unconnected plugs plz?
Discussion in 'General 1000RR Discussion' started by Scott, Jul 29, 2013.
  1. Scott
    Scott Active Member
  2. ColinBR
    I'm guessing here but is it maybe the plug for the O2 sensor.
    Has the black end been plugged with an O2 eliminator?
  3. levin
    levin Active Member
    Looks like Indicator and tailight plugs from rr8??
  4. barry107
    barry107 Active Member
    Natural plug is Brake/tail light as Levin said
    O2 sensor is a black plug with 4 pins as Colin said.
    #4 barry107, Jul 29, 2013
  5. Scott
    Scott Active Member
    Oh that's great boys thanks. Do u need to get an O2 eliminator ?
  6. ColinBR
    If there isn't 1 already in there and you have a powercommander then yes.
  7. barry107
    #7 barry107, Jul 29, 2013
  8. Scott
    Scott Active Member
    I'm probably goin to fit Bazzaz but not sure if il do it straight away now. Might jus try get it out on track and fit that at a later time. Will I loose power without an elimator
  9. levin
    levin Active Member
    O2 eliminator plugs in on the left hand side of the frame on the rr8,
    I used a 50p resistor on mine and its fine,
    I had to disconnect them 2 plugs when fitting an r&g tailtidy.
  10. Scott
    Scott Active Member
    Oh it's just a resistor. Il get another one of those. I'm goin to stick a resistor into the steering damper plug ? Will be fitting a gpr damper
  11. levin
    levin Active Member
    Not sure what resistor to use for the damper , but this is what I did for o2 eliminator
  12. Scott
    Scott Active Member
    Il get one thanks
  13. Scott
    Scott Active Member
    What are these three plz
  14. Scott
    Scott Active Member
    Shit wrong pic
    And I just need to know the one I'm holding plz
