What Engine Oil for my Blade?
Discussion in 'Maintenance' started by Remal, Apr 24, 2011.
  1. Remal
    OK I have a Ltr or so of 10w40 qhat I kept for topping up the speed triple. It never used any oil.
    So thinking about the blade. just checked and its recommended 10W30 oil
    Worth getting the right stuff? and what make do people recommend? Use?
    Yes bike oil is expensive but I believe it is bloody important so worth paying the extra for the right stuff.
    thoughts?
  2. flatstickHRC
    flatstickHRC Active Member
    I always use motil 5100 on my bikes.
    10 40
    Just had my first service a couple of weeks back and used it on he blade too
    1300 miles on it now and not used a drop
    Always used it in my race bikes and my enduro bike and it's good stuff
    10 40 is fine for our climate.
  3. Remal
    Ahh forgot to say it's Semi not fully
  4. matt
    matt Active Member
    i used used silkolene in my old gixer,
  5. Brym
    Brym Active Member
    10w-30 fine for all year with quick warm up. The main thing is to make sure whichever oil you use it has the correct specs it should be on the black sticker near the oil filler cap some JASO & API spec numbers from memory. most of the known brands like Motul, Castrol, Silkolene etc etc should meet these but check before you buy some don't.
    Good site to mail order from is Opie Oils
    or hein gericke sell Motul or Fowlers stock lots of Silkolene which is recomended for Hondas., Best to use the same oil for topping up with if needed.
    As for fully or semi you can read pro's v con's all day long and not find an answer. Either will be ok its more important that you change it regular as recommended or sooner especially if you take it on track alot.
    #5 Brym, Apr 25, 2011
  6. Remal
  7. *AL*
    *AL* Active Member
    Just done an oil service on my 2005 Blade and used Silkolene, gear changes are alot smoother now.
  8. flatstickHRC
    I was advised to not use fully syn on the blade until it's got a few thou on the clock
    Will use probably use fully syn on it's next service (1 year).
    I'm pleased with that motul I use though.
  9. megawatt
    megawatt Well-Known Member
    Some bikes, not necessarilly Blades suffer clutch slip with fully synth. I've always used semi.
  10. flatstickHRC
    checked the oil after a great ride out today
    bike has done 1000 miles since first service and TBH this is the first time ive checked it since the service
    the dipstick showed about mid way, i put 100ml in and its at the upper level now
    100ml for 1000miles on a new engine is pretty good i reckon
  11. Remal
    again just checked mine. done over 700 miles since the first service and not dropped anything yet.
  12. flatstickHRC
    Seems the newer type are much improved over the 08
  13. GSP
    GSP Active Member
    I would just use what the book says to use.
    I bought Silkolene 10/30 Semi Synthetic.
    I've done about 700 miles since picking the bike up and the oil level hasn't move which I have been quite suprised about.
    700 miles and no oil usuage on a 2009 Repsol Blade. It defo won't be using 1ltr per 1000miles that the service book says may be the case.
  14. davy19
    davy19 Active Member
    I use Castrol Power 1 Racing 4T 10W-30 Fully synthetic in my bike.
  15. djfleming22
    djfleming22 Active Member
    use the same stuff ................... Castrol Power 1 Racing 4T 10W-30 Fully synthetic in my bike. Very happy and no clutch slip
  16. flatstickHRC
    just checked my oil tonight and it took about 150ml since i last topped it up
  17. dan.1moore1
    Surley you need to top up with the same oil they put in on the 600 mile service.. Should say on your reciept for the service mate
  18. Remal
    I have the same grade of oil but a different make. was highly recommended not to use fully and the blade has not used a drop since the 600 mils service. now on 15000 miles. after talking to opie oils they say the motul 10w40 is ideal for the blade. All good so far
  19. dan.1moore1
    Same here.. 1500 miles and not used a drop
  20. flatstickHRC
    Mine went about 1000 miles (after first service) without using any but it has used a bit over the past 500 or so miles.
    No more than any other bike I've had I reckon though
