What have I done to it?
Discussion in 'General 1000RR Discussion' started by Dave The Blade, Sep 10, 2015.
  1. Dave The Blade
    Dave The Blade Active Member
    So after replacing the nose cose I've put it all back together and it wont start. It turns over but that's it. I've pulled it apart again and re-checked all the connector blocks, vacum lines etc. all connected. Should I be hearing a fuel pump priming becasue if I should I'm not.
    Anything simple I could have missed or have I killed another one? Oh and before anyone asks, it has got petrol in it it.
  2. johnd
    johnd Active Member
    Have you accidentally knocked the kill switch off? Worth a look.
  3. N1xxl
    N1xxl Member
    If you were in the nose I would be looking at Tilt switch and double check all block connectors.
  4. red5
    red5 Well-Known Member
    Are you sure you have all the connectors fitted properly, there is a 24 pin connector behind the lefthand fairing that if not connected properly will give the symptoms you describe.
  5. Dave The Blade
    Thanks chaps, checked the kill switch and seems good i.e it turns over. Bank angle sensor has been dangling in the breeze whilst apart so I'll check that and yes I have had the left hand fairing off so I'll look there. I'll report back and thanks again for taking the time to reply.
  6. Dave The Blade
    Red5, you are one clever @**!!!er. I'd pulled it apart and just left it loosley together when I took the fairing off so it looked connected when I came to put the fairing back. Thanks very much and thanks too to johnd and N1xxI for the sugestions much appreciated.
    • Useful Useful x 2
  7. red5
    Happy to help.:)
  8. N1xxl
    N1xxl Member
    9 times out of 10 its the simple things. Happy to help where I can.
