What have you done to your 1000RR?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Rob, Jan 23, 2011.
  1. Rob
    Rob Administrator
    What mods have you stuck on your bike? Mine has an Akrapovic carbon can. Thinking of improving the rear shock soon.
  2. CastrolCraig
    CastrolCraig Active Member
    mines a long long list!
    Kit ECU
    Chris Meyhew Blueprint
    Ten Kate Velocity stacks
    Flapper Valve mod
    Pair valve blocked off
    Standard loom shortened, lightened
    HRC Rear Subframe
    pipercross filter
    HEL Lines
    Grimeca kit fully floating wavy discs on dry wheels, standard on dry
    Factory Brembo 18x19 Master Cylinder & Lightech remote span adjuster
    SBS Dual Carbon Pads front & rear
    MCT reworked forks, KTEC 25MM Internals, 5w oil, 9.5 springs
    Ktec Modified Rear shock
    one off blue flame can & link pipe, slighlty shorter can & wider than normal bore pipe
    ANR Performance Superbike Bodywork
    Power Commander 3, mapped by Trig
    PP Tuning Rearsets,
    PP Tuning Clutch Lever
    PP Tuning Endurance Filler cap
    PP tuning stand bobbins
    R&G Crash Bungs
    Venhill quick action throttle
    Renthal grips
    Renthal Sprockets
    Tsubaki Pro chain
    Factory Pirelli Supercorsas
    Its currently undergoing a pre season refresh/makeover with some of these parts only recently being added, awaiting a factory TTX46PRXLS Ohlins Shock & Full Akra Evo Ti System, once those arrive the current rear shock, can & link pipe wil be sold.
    heres what it looked like back in december 2009 with a relatives 09 racer.
  3. Ryan
    Ryan Active Member
    My RR5 is very weak compared to the list above lol
    Micron half system
    Pipercross filters
    shorty levers
    hel brake and clutch lines
    flapper valve mod
    r&g number plate bracket (still to fit, been to cold)
    Nothing else at the moment. Only got the bike in september and havn't to the end of the year been getting used to it. bit of a different from my k6 600 gsxr.
    #3 Ryan, Jan 23, 2011
  4. RepsolBlade
    RepsolBlade Active Member
    Repsol RR5 on 06 Plate, waited till april to pick it up hence the 06 plate ;)
    Quill Evo, tailor made to my requirments by James at Quill!
    BMC Race Filters
    Airbox Flapper Mod
    Power Commander PC3
    ASV Levers Black(standard Length)
    Carbon Hugger
    Carbon Exhaust heat shield cover
    RR6 Indicator Lenses
    R+G Tail Tidy
    Venture Shield
    Goodridge Hoses F+R(Race Set)
    Oxford Race HotGrips( Not just a summer ride)
    Datatool Thatcham Alarm.
    Repsol Seat Cowl
    All brand new original bodywork, due to falling over as gettin out of garage!!!( have a complete set to play with lol)
    Swingarm bobbins
    To Do List:
    Fit the Brand new Shock(standard)
    Fit the RR6 Swingarm, which is in paintshop being coated black to match Frame.
    New Phillips Headlight Bulbs!
    Black rearsets, not sure which yet!!
    New Chain and sprocket kit! And thinking of tryin out those Armstrong wavey's??? still unsure about that!!
    #4 RepsolBlade, Jan 24, 2011
  5. Ryan
    Ryan Active Member
    I had the armstrong waveys on the my k6 600 after a 'mishap' lol. They were superb
  6. viper_biker
    viper_biker Active Member
    Wheel, exhaust, PCIII, suspension and some carbon.
  7. Si.
    Not changing the can... fast enough already, and can't be arsed with a PCIII/V to map it properly to match the can...
    I've added:
    Carbon can cover
    Carbon heel guards
    Carbon seat sides
    Carbon front mudguard
    Carbon rear hugger
    Carbon chain guard
    Carbon yoke
    soon adding some nice levers, and got some carbon mirror covers on the way, and some pro-bolt stuff.
  8. stu-pendus
    stu-pendus Active Member
    Having gone completely over the top on my old 748R,Speed triple and Gsxr1000 K6,i've left my '08 Blade fairly standard apart from a full Akrapovic system(which adds a tiny bit more BHP over the slip on as the original down pipes flow realy well,pipercross filter,PC111 which had a dyno set up(Crescent Suzuki),Pazzo long levers(i love the feel of these)R&G tail tidy and rad protector,double bubble screen,suede seat cover,took off the rear footrests(what a palaver) and a rear seat cover.The suspension was set up for track use by an old mate of mine Francis Williamson.This bike is a keeper now(i cant belive it realy) so my have a gas flow done on it by Alan Hessledon with HRC loom and cams and def a quick shifter in race pattern but then why ruin a good road bike so undecided as yet.
    #8 stu-pendus, Jan 26, 2011
  9. megawatt
    megawatt Well-Known Member
    Right here goes;
    929 front forks n bottom yoke
    MFW German Top yoke
    Hagon springs
    CF Harris mudguard
    954 front wheel
    ABM bars
    mirrors
    German fairing with Gilera runner 50/55 watt lamps
    Rizoma reservoir
    moved ignition switch
    braided lines
    fairing brackets
    radiator guard
    footrest brackets
    Metmachex lower brace on RRW swingarm
    Nitron race shock
    bigger battery
    RnG mushrooms
    Front Spindle mushrooms
    Modded black chrome stubby
    K&N filter
    Extended cables
    LED indicators and flasher relay
    15 tooth front sprocket
    Mods this winter/spring
    954 rear wheel on RRW spindle
    custom 525 sprocket on 6 bolt 530 954 carrier
    stainless hugger
    stainless chainguard
    more carbon fibre bits
    Home made stainless parallel silencer with internal baffle
    low mileage RRX engine, overhauled
    GSXR tail unit
    Custom seat
    modded subframe
    LED tailight
  10. stu-pendus
    Wow,that is a man sized list,just seen the pix on another thread,nice one m8y.
  11. megawatt
    Thanks Stu, I see you're not too far either. Fancy a meet up next Sunday?
  12. stu-pendus
    Would love to but working i'm afraid.
  13. jam
    jam Active Member
    2009 CABS model
    Rear seats - PPtuning
    Levers - ASV
    grips and bar ends - Rizoma
    Glass - Honda Racing
    Mushrooms - Honda Racing
    Licence suport - R&G
    Wheels - Marchesini
    Braking disks - Braking
    Exhaust - Full Akrapovic Evolution
    Ar filter - BMC (Foi eliminado o retorno de ar ao filtro)
    Rear seat removed - Rear seat protection Honda
    Sprokets - Renthal 520
    Chain -DID 520
    Gear indicator - GI Pro
    Bazzaz w/ Quick Shift and traction control
    Speed corrector - Speedo Healer
  14. stu-pendus
    Ola and bom dia,thats a fair list of mods that you have done to your bike,any pictures and how are you getting on with the Bazzaz QS and TC ??
  15. Rob
    Rob Administrator
    Serious moddage! Interested in the traction control too! Any good?
  16. jam
    jam Active Member
    Hi Stu, the picture is all ready in pictures post.
    Thanks for the wllcome in Portuguese.
    The Bazzaz increase lots of power, I bought it in Portuguese representant and I did my own setup for it, every time I want i redisign a map.
  17. jam
    jam Active Member
    Yes, it works very well. I use the bike all the year and its better when the floor is wet. At wet condition is very good to have it. In dry conditions I prefer not to need it.
  18. matsuyama
    matsuyama Active Member
    Had my black & silver cbr1000rr-7 18 months list so far
    Akrapovic hex carbon can
    Pazzo short levers
    Honda single seat cowl
    R&G
    tail tidy, aero crash bungs, radiator guard
    Flapper mod
    Tinted DB & headlight protectors
    Renthal medium compound grips
    Front & rear sliders
    I'm either going to sell her or get a set of Sato or Gilles VCR rearset.
  19. JM1
    JM1 Active Member
    2008 model:-
    Leo Vince carbon fibre end can
    Power Commander V & O2 Sensor Eliminator
    Carbon fibre tail unit
    Carbon fibre rear seat cowl
    Active folding billet front brake lever
    Honda high screen
    Honda carbon fibre rear hugger
    GB Racing engine covers
    R&G tail tidy
    Renthal rear sprocket (+2)
    GB Racing paddock stand bobbins
    R&G radiator protector
    #19 JM1, Feb 18, 2011
  20. hrcblade
    hrcblade Active Member
    Leo Vince carbon can
    honda screen
    pazzo levers
    honda rear hugger
    R&G tail tidy
