What Hugger ?????? V
Discussion in 'General 1000RR Discussion' started by Speedytwin, Jun 21, 2011.
  1. Speedytwin
    Speedytwin Active Member
    I'm liking to get a Hugger for the 08 Blade. I've seen the Honda one but I don't like the way it sits up off the tyre if you know what I mean. I like a hugger to sit nice and tight on the tyre with out being able to fit your arm around between the tyre and Hugger. I have a pyramid one on the SP1 and it's a lovely fit so was thinking of getting one for the Blade aswell. Has anyone here got one fitted and what are your toughts on it.
    So get some pictures of yours up and help a brother out.
  2. JM1
    JM1 Active Member
    You might thankful for that gap if you ever fit a 55 section tyre :)
  3. dan.1moore1
  4. garyauk
    garyauk Active Member
    I agree
  5. Remal
    was thinking this also. Hoping to get my supercorsa's fitted soon
  6. flatstickHRC
    flatstickHRC Active Member
    King carbon on mine and plenty of room for the 55.
  7. Nutty Tart
    Nutty Tart Well-Known Member
    Funnily enough I have just taken a tight one off my Blade and fitted a Honda copy with the gap :whistle:
  8. dan.1moore1
    I have a carbon honda copy and now with a 55 rear tyre there is not much gap at all so don't get anything to tight if you think you will ever go up a profile
  9. Speedytwin
    How have you lot found it with the 55 rear tyre fitted is there much of a difference in the handling
    It's not something I ever tought of doing. I'm running pilot power 2CTs and I think the bike handles like its on train tracks. It nearly driver it self if ya know what I mean.
  10. flatstickHRC
    A 55 will make it feel even better especially when it's on it's side
  11. dan.1moore1
    well i bought the blade 3 months ago now and on the first ride the first thing i noticed was it was harder to lean the bike compared to my 600 but i put it down to it being a bigger heavier bike.
    I had new front and back tyres last week and the back being a 55 and it was shocking how faster and easier it was to lean the bike over. I honestly nearly led it down on the first bend i came to.Also i couldn't get the last few mm of chicken strip of the 50 qualifier but iv got it off first day out with the 55
    defiantly an improvement
  12. Nutty Tart
    Yup cheers dan .. I am deffo going up to a 55 on the next rear (soon) as I would like a faster turn in . I don't have any chicken strips at all on the rear so I can lay it over but its an effort at times . I would like an easier time of it . It deffo seems to be a popular change with the folks on here .
    #12 Nutty Tart, Jun 23, 2011
  13. JM1
    JM1 Active Member
    "Chicken strips" are good. They indicate that you're not using all of the available lean, which you shouldn't be cos you might need it and max lean normally isn't the fastest or safest route anyway :boink:
  14. dan.1moore1
    Its the most fun thou
