what is this ??
Discussion in 'General 1000RR Discussion' started by tazmania_1981, Sep 15, 2014.
  1. tazmania_1981
    tazmania_1981 Active Member
    just removed the left middle cover to install the gear indicator
    and saw this
    what is this round thing
    also this pipe is coming out of it is blocked by a big screw
  2. Frost1
    Frost1 Active Member
    Looks like the solenoid valve for air flap, blocking this pipe keeps it open all the time.
  3. tazmania_1981
  4. tazmania_1981
    I think i need to go to haynes manual and find out
  5. Frost1
    Look up flapper mod, its an air flap that is closed until around 5000rpm when it opens. If you plug the pipe that operates the solenoid it never closes so a bit more induction noise and no air restriction at all. HTH.
  6. GappySmeg
    GappySmeg Well-Known Member
    Your bike has had the flapper mod done by a previous owner... although not been done very pretty, looks air-tight and thats all that matters
  7. graemewalker
    graemewalker Elite Member
    Usually put a plastic plug in
  8. Gilesy
    Gilesy Elite Member
    Or a golf tee ;)
  9. PeterT
    PeterT Active Member
    why does it need to be air tight?
    The pump is in the front fairing and all it is doing is creating a vacuum for the flapper valves in the intakes, simply pulling the pipe is sufficient keeping the electrical connector on keeps the ECU from throwing up an engine light fault.
