Hi Guys, I own a 2015 Repsol, recently put on a Austin Can..and was told I may need an ECU flash? Bike is to be used for track days.. Also do these bikes still take Power Commanders? Or is this not needed once a map is put on? Looking for a quickshifter- any recommendations to what is good? I did was down shifts but have a rear this is only possible on 17 plate onwards bikes?...is there no way around this? What are the traction control options? Are these any good? Thanks
Will you pass noise testing on your track days? Translogic is4 are the best quick shifters you can fit when you do research. You'll not be able to have downshifts with autoblipping though on a cable throttle. Requires ride by wire throttle. Not sure about ECU flash on the 2015 blade, think you might find more reliable info on piggy back fuel module (PCV or bazzaz). Don't go down the Hilltop route though. Think Bazzaz is a good place to start your research as regards traction control/fuel control.
