My side panels are off, and looking at the top were the radiator mounts on, something looks missing as on one side there is a nut and the other side nothing. I pulled it out little to see if there is a thread and I do no see one... Also this spacer fell out from somewhere.... Anyone know what this is and what I'm missing?
The spacer is part of the engine mount. do you have crash bungs at all. Think you need another bolt for the rad if i recall
The microfiche seems to show that there isnt a bolt there ? http://www.hondapartshouse.com/oemparts/a/hon/52c5a37ff8700250a4234d1c/radiator Heres a link to the spacer http://www.hondapartshouse.com/oemparts/a/hon/52c5a37cf8700250a4234d1b/frame Item 7
Bolt only on one side......mine exactly the same....the rad sits over one of those lugs and bolts to the other.......no dramas !!
Still confused...can't see to figure out were the spacer goes.. I have crash bungs fitted and they are already on the bike... Just removed the crash bung..and they have a spacer already there same diameter hole, and little taller..and is black.. So were does this silver one go?
Difficult to tell from the picture but the spacer looks like an engine to frame spacer, maybe it's been sat in there since the crash bungs were fitted, new spacers may have been supplied and fitted with the crash bungs.
Got there in the end...yep, ended up being the spacer that goes on the rear between the engine and mount..was awkward to get it..bit guessing it came loose when I removed the crash bung..
