Wheel bearing problem
Discussion in 'General 1000RR Discussion' started by Tony Burrell, Jul 28, 2019.
  1. Tony Burrell
    Tony Burrell Active Member
    Hello I have just installed new front bearings on my RR6 2006.
    The tube is tight up to both bearings and is quite stiff to turn by hand and feels a bit nothchy when turning.
    Is this normal?
    You can't even move the tube from side to side.
    The bearings that I have used are koyo 6005RS, that's what it says on the bearing.
    But on the packaging it says
    60052RSCM
    GSR
    N1903
    Any help would be much appreciated
    Thanks Tony
  2. Bikeboy
    Bikeboy Active Member
    From my experience. Yes
    When you fit the bearings they will butt up to the tube. You may have been a little too enthusiastic when tapping them in. If I remember correctly there is a side you fit first. That's the one that gives the wheel its central location. The other one is governed by this.
  3. Tony Burrell
    I followed the haynes manual instructions which said to put the right hand side one in first which I did.
    The right hand side one I class as is when I'm sat on the bike.
  4. red5
    red5 Well-Known Member
    How did you install the new bearings, pressure should have been exerted on the outer race of the bearing only.
  5. Bikeboy
    I suspect the bearings are just a little tight against each other.
  6. Selmer50mark
    Selmer50mark God Like
    I think The tube is there hold the bearings apart by the inner bearing race so when you tighten the axle bolt up you don't crush the ball race ,,,, if there was no tube you would just crush it all in when tightening up ,,,,, it also stop crud getting to the axle bolt ,,,,
  7. Tony Burrell
    I just used the old bearing then a socket on the outer race
  8. Tony Burrell
    Do you think it would be ok to put back together with the bearings being tight up to the tube?
  9. Selmer50mark
    When you tap in a bearing in you feel a rebound on the drift / hammer as it seats in ,,, assuming this has been done and the axle slides in with all seals and spacers in place hand tighten the axle nut and check the wheel spins freely and no side movement then you can tourqe up and check again ,,,,,,, without a tube you risk crushing the wheel centre when tightening up ,,,,,hope this makes sense
  10. red5
    By using the old bearing you have probably inadvertently put pressure on the inner bearing race causing damage to the ball races.
  11. Selmer50mark
    As above, ,,,,,, if you put your finger inside the bearing and turn it it should be a smooth rotation, ,,,,,, if notchy it sounds like they are damaged ,,,, it sounds like you have used the socket on the outer race of the old bearing against the New one to drive it in ,,,,,,, is this correct?
    Top tip put New bearings in the freezer to contract them first for about 10 mins ,,,, they go in easy
  12. Tony Burrell
    Yeah that's exactly what I have done as the socket I used to tap the new bearing in wouldn't go inside the hub so I used the old bearing.
  13. Selmer50mark
    Ok ,,,, I think you have damaged them ,,,,,, the inside race is I think wider/deeper than the outside race therefore you have put pressure on that and not the outer by using the old bearing
  14. Tony Burrell
    Ok, I'll knock them out if I can move the spacer.
    If I grind the inner race of the old bearing so it's not as wide.
    Or ill try and find something else
  15. Boothman
    Boothman Elite Member
    Why not use a socket?
  16. Tony Burrell
    I did but it wouldn't fit inside the hub so had to use the old bearing
  17. Selmer50mark
    I think you need to start again with new ones and the right size socket ,,, don't risk it ,,,,,,,, they are probably damaged
  18. Tony Burrell
    OK no problem thanks for your help mate
