I have just bought a set of wheels (2014). The rear does not have a sprocket, no problem I will fit mine from my 2009 wheels. Am I correct in thinking, that the rubber damper thing will also move across? And how much are these dampers to purchase, just in case I need to replace?
You can just use the cush drive from your 09 Although if you want to replace they are £43.69 exc VAT from Fowlers
As above - they are the same. http://parts.hondaofbournemouth.co.uk/products/2008-133/rear-wheel-cbr1000rr-8-3342.aspx
