where is that pipe ment to go
Discussion in 'General 1000RR Discussion' started by alec, Jul 1, 2017.
  1. alec
    alec Active Member
  2. alec
    alec Active Member
    2005 fireblade with a pipe to no where
  3. thewiz
    thewiz Active Member
    breather tube that leads underneath the bike
  4. Muffking
    If it's the one which dangles down to the lower fairing as a drain, then I'm with thewiz and it should be connected to either the header tank overflow or the petrol tank overflow.
  5. alec
    alec Active Member
    have breather tube that goes from tank to under bike but . Before it goes under the bike there is a T pice with second tube coming back up ?????? Can't find where it goes??????
  6. Muffking
    There should be 2 pipes coming out of the hoop attached to the side stand bracket. Trace the end connected to the T-peice and see if it's for water or fuel. That should help figure out where it goes.
  7. alec
    alec Active Member
    it's definitely a drain tube. but can't see any where it fits to. sorry about the crappie drawing.
  8. alec
    alec Active Member
    yes it dose but from what
  9. thewiz
    Locate your coolant reservoir, there should be a drain port that it connects too
  10. alec
    alec Active Member
    the coolant reservoir over flow one seams to come down on the other side
