Just purchased a carbon lower heat shield from Powerbronze. I can't for the life of me find where to attatch it. The two attatchment holes don't seem to line up together with anything on the bike. Do i need to remove the metal heat shield ? If so, the rear set has an attatchment to this ?? Anyone got any ideas ?
Should fit into the original holes. Mind you I cut the alloy cover on mine in half and painted The lower bit black to blend it in a little.
The original one has been taken off mine, but that is an Akra one. From Phantom's pic I reckon it needs to be removed. Click on pic for a bigger image.
Thanks for the replies. Just gone out there and had a look - the bottom of the shield is blocked by the metal marked by the yellow arrow. This seems to be the rear set attatchment to the metal heat shield - can this attatchment be taken off and if so i'm assuming that there is a hole for the lower part of the carbon shield ??
No problem Stev, that's what the forum's for, picture whore'ing So here's another after i chopped the old brake reservoir off and fitted the same one you have.
Finally got it on - just gotta get some better bolts for the fixings Thanks to all for your help Steve
