Which battery charger conditioner?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Andrew, Sep 20, 2011.
  1. Andrew
    Andrew Active Member
    I was think ahead to when the bikes got it's feet up through the worst of the winter really.
    A month or so back I read a recommendation for a battery charger/condtioner and they said it was head and shoulders above what all the other models/brands offered.
    The thing is I can't remember where I read it, it was either MCN or a bike mag so I can't find out which make and model it was!
    Anyone have any ideas or recommendations for me
  2. kpone
    I swear by my Optimate 4, Andrew.
  3. Andrew
    Cheers just had a look, they're quite reasonably priced too.
    I don't think it was the one they were recommending tho.
  4. kpone
    I haven't got a clue how it works, mind. The instructions may as well be in Latin. I've got the permanent connection cable wired straight onto the battery. Just ride the bike in and plug it straight onto the charger.
    I did end up dragging it across the garage one day and it started making an awful noise. I emailed tec-mate in Belgium on a Sunday and they got back to me in about 20 minutes, falling over themselves to help me sort it. That goes a long way with me.
  5. Andrew
    It does sound the part and good customer service is always a real bonus.
  6. stevebetts
    stevebetts Well-Known Member
    I've always used the Oxford maximiser.
    It works!
    I have even recovered a dodgy battery with it
  7. tandbiskits
    tandbiskits Active Member
    Optimate again for me, permanently wired to the battery,plug it in & bugger off for a while..
  8. Nutty Tart
    Nutty Tart Well-Known Member
    Yup same here .. Optimate with hard wire onto battery .. although I don't need it much since fitting the LiPo
  9. Moily
    Moily Active Member
    +1 for the Optimate. Always gets great reviews as well.
  10. Remal
    +1 I have 2 and used for years. never been a problem at all
  11. JM1
    JM1 Active Member
    Optimate.
  12. JM1
    JM1 Active Member
    I thought you couldn't use a tricke charger with a LiPo battery?
  13. Andrew
    Whats a LiPo battery then?
  14. Nutty Tart
    Same as in the smart phones LithiumNanoPhosphate .. totally unnecessary cost wise but I'm on a weight saving exercise and its over half the weight .. and whereas the standard battery would die after three weeks without charge this one still has loads of kick
  15. Movistar
    Movistar Active Member
    agreed
  16. Andrew
    That sounds like it could be handy, a couple of times i've been doing something to the bike and left the ignition on so the daytime running lights were also on and then when I realize go to start the damned thing there's not enough juice to spin it over fast enough to start!
    It doesn't even have to be that long either!
  17. Andrew
    Well it looks like everyones agreed on the Optimate 4, I don't think I've ever had such a definitive answer.
  18. Moily
    Moily Active Member
    Yeah, I've got an Acumen alarm and a Tracker fitted on mine but left the Tracker to die as it drained the battery in 5 days without riding. :-/
    Not heard of these LiPo batteries though. anyone got a link? and can you not recharge them with an Optimate?
  19. Si.
    Optimate 4 here too. Plus if you lick the + wire when it's on, you get a lovely kick of electrickery down your toungee. Laaaverly.
  20. Sossige
    Sossige Active Member
    Another vote for Optimate/Accumate here.
