Which brake fluid
Discussion in 'Maintenance' started by Dano28, Jul 20, 2014.
  1. Dano28
    Dano28 Active Member
    Need to change and bleed fluid, what brake fluid do people use?
    Cheers
  2. Gilesy
    Gilesy Elite Member
    I just use DOT4.. nothing fancy, same for my clutch
  3. Dano28
    Ok cool so if I just grab a branded litre of Dot 4
  4. Gilesy
    Gilesy Elite Member
    Yes.. good enough.. I don't even think I used branded last time.. brakes are great :)
  5. Muffking
    Motul Dot4 for me too, even used it on the track bike as it doesn't absorb moisture as quick as Dot5.1, so you can leave it stood between track days. Just stick to a known brand.
  6. PeterT
    PeterT Active Member
    Dot 4, change it every pad change, 3K miles.
  7. Slick
    Slick Elite Member
    Any DOT 4 but ATE Super Blue is my fav. Cheap and cos its Blue you know you have flushed out the out stuff.
  8. rogerdodge
    rogerdodge New Member
    I use that in my track bike and seems good. Isnt strictly ok for the MOT though....
  9. M3NTALIST
    M3NTALIST New Member
    Sorry for the hijack OP, but could someone tell us how much fluid I would need to bleed front and rear on a standard RR9 please?
    Andy B
  10. Muffking
    A 250ml bottle did my RR5 if that helps.
  11. Slick
    Slick Elite Member
    Really, I didn't realise that, thanks for the heads up!
  12. M3NTALIST
    Thanks Muffking, I can't imagine mine will be much different, cheers pal.
    Andy B
  13. sps170373
    I used motul dot 4 when I changed my calipers and master cylinder
  14. Jbully_uk
    Jbully_uk New Member
    RTFM :) to be sure but almost always dot 4
  15. TheRamJam
    TheRamJam Well-Known Member
    Dot 4 Silkolene Universal Brake & Clutch fluid
  16. Souleh
    Souleh Active Member
    Any decent branded dot4 is grand. I use motul rbf660 for racing which is prob overkill for road riding but would be ideal for any track stuff :)
  17. Dano28
  18. Muffking
    Not seen that one before. Mine was badged just Dot 4, although 3 & 4 can be mixed, 5.1 cannot.
  19. Dano28
    I tried to order the dot 4 from DT but Andy said it said use this product code that turned out to be that product, boiling point seems all good, so fingers crossed :/
  20. MadG
    MadG New Member
    Motul Dot 3&4 is fine. If you've ordered by mail or been rough with the bottle leave it a day or so to settle as it will be full of micro bubbles.
