Which can's meet track day noise limots
Discussion in 'General 1000RR Discussion' started by Carl Abbott, Oct 16, 2016.
  1. Carl Abbott
    Carl Abbott Active Member
    Hi,
    I jave a Leo Vince Silencer but recently failed the noise test at Silverstone. Luckily, managed to sort it but would like a more permanent fix i.e. new can.
    Any recommendations welcome.
    Anyone running an Akrapovic can?
    Thanks
  2. tuktuk
    tuktuk Elite Member
    R77 slip on 103db with no baffle.
    Think limit is 102 but they have always signed it off with a slight twist of the face.
  3. Carl Abbott
    Thx, didn't think about the R77
  4. Scott
    Scott Active Member
    Mhp are good for tracks
  5. Carl Abbott
    Thanks. I'll check them out
  6. scarra
    scarra New Member
    ive got a yoshi on mine and went through Oulton park at 99
  7. Dazzler54
    Dazzler54 Active Member
    Akra's are normally relatively quite.
    Use some logic when looking.....if the can is tiny, is can't have much in the way of sound reduction so the likes of Austin racing are going to be loud compared to Yoshi R77's for example.
    I've repacked noisy exhausts in the past with reasonable success so might be worth considering.
  8. TheRamJam
    TheRamJam Well-Known Member
    The standard can :eek:
    • Dislike Dislike x 1
  9. And7rp2
    And7rp2 Elite Member
    The Austin racing exhaust has three baffles and gets as low as 98db's or as loud as 108dbs how ever they are expensive, but you get what you pay for,quality bit of kit and if you go to the NEC they offer 10% discount
  10. paul
    paul Active Member
    Same here....My yoshi was measured at 99db at RAF Odiham with no baffle.
  11. pete954
    pete954 Active Member
    Stock exhaust at 5500 measured 100db. That was No Limits static test.
    Sent from my GT-I9505 using Tapatalk
  12. CBR-Pete
    CBR-Pete Active Member
    I got the full Akrapovic on mine which runs 102/103db's without the baffle, I take the baffle with me just in case you get a jobsworth on the sound testing. Baffle in it was 98db's.
