Which Chain Lube?
Discussion in 'General 1000RR Discussion' started by slasherr, May 17, 2015.
  1. slasherr
    slasherr Active Member
    Hi All,
    As it says in the Title really what one/s do you use and why?
    I've tried the following
    Silkolene - ok but a bit flingy
    Motul - Not a flingy
    Profi Dry - Decent
    Sdoc - ok but quite pricey
  2. Robbo52
    Robbo52 Active Member
    Wurth Dry lube - no fling and seems to work well, Ive been using it for a couple of years now :)
    • Agree Agree x 3
  3. shackbleep
    shackbleep New Member
    Seconded
  4. MPJ
    MPJ Active Member
    I was recommended Motorex racing by my local chain/sprocket shop. Also used Muc-off. The Motorex lasts longer and is the same price. Does anyone else find the chain goes grey very quickly and collects a lot of grit with these lubes on ? I have tried cleaning the chain with WD-40 then just leaving a layer of WD-40 on. Chain stays cleaner and the rollers move more freely than with the lube...though I realise this isn't ideal for the x/o rings. ...I live up a (very) long gravel drive !
  5. Repsol Rob
    Repsol Rob Elite Member
    Wurth for me..... no mess
  6. Stevie_d
    Stevie_d Senior Member
    Just got some the other day , tried all kinds but this seems very good
  7. SimonRR
    SimonRR God Like
    Yeah Wurth here too :D
  8. RRoss
    RRoss Active Member
    Wurth too:)
  9. JimGreen
    JimGreen Active Member
    And me too "Wurth"
  10. Moon
    Moon Active Member
    Used nothing but wurth for last 4 years :)
  11. Barstewardsquad
    Anyone mentioned Wurth?
  12. bladeaddict
    bladeaddict Active Member
    :) Just to be different I've been using sDoc for the past 7 months.
    There’s a conspicuous lack of fling, leaving your chain
    coated in a rust-and-grime-repelling coating,
    whilst your back wheel, tail unit and leg remain
    clean. It can easily be removed by
    sDoc’s chain cleaner, too, for easy maintenance.
    This spray also fails to create the paste-like
    sludge of lube and road grit that infests many
    a sprocket housing, and keeps all grime well
    away from the chain itself. When you remove the
    protection with chain cleaner you have a clean
    chain – not a well-lubricated rusty and dirty one.
    However also used Wurth which also ok, but feel sDoc
    is the slightly better overall product.
  13. AABIKER
    AABIKER Member
    Have been using motul for a couple of years & find it ok, chain a little rusty & a bit flingy. I'am about to switch to SDoc100 Heard this really is the nuts.
  14. N1xxl
    N1xxl Member
    If EP90 is good enough for HRC then..........
  15. Keith rosborough
    Keith rosborough Active Member
    Used doc 100 for 3 years and have only had to adjust chain about 4 times and covered about 5 k would use no other and use there chain cleaner apply leave for 20 minsd and wash off with hose pipe and chain looks like new
  16. Mike07
    Mike07 Active Member
    Wurth Dry lube - no fling........ If you like cleaning thick greasy crap off the inaccessible areas of your bike use something else.
    Mike.
  17. exuptoy
    exuptoy Elite Member
    Picked a tin of Yamlube when I called into JT's in Swansea, only because I had run out. It's ok but does seem to coat the wheel if you use too much.
  18. old git
    old git Active Member
    Wurth.
  19. Wozza
    Wozza Elite Member
    Looks like I will be buying a can of Wurth in the morning I do have a can of Silkolene chain wax which is good but does fling,
  20. Scott
    Scott Active Member
    Castrol
