People Looking at torque wrenches, specifically a Draper 1/2 inch 40-210 nm. Good quality v price. Will this cover most requirements for a 2008-10 Blade? Handy to have a 3/8 drive for smaller torque settings? Advice please chaps Many thanks in advance Mike
Id love to know this info too, watching with interest. Aslo I dont suppose any of you tool addicts have a spare 32mm socket for sale, going to need one for me rear axle nut as I top out at 30mm (doh)
I have a 3/8" and two 1/2" Teng torque wrenches with reverseable rachet heads, expensive but very good quality
Halfords torque wrenches are quite good value especially if you've got a Halfords discount card. We use Norbar at work so they have to be generally idiot proof.
I use a norbar as we use them at work. I can also take it in to be calibrated too so quite handy for me
For a budget tool these are good about £20 Clarke CHT141 - 1/2" Drive Torque Wrench - Machine Mart Or if you have more to spend I would buy a halfords pro good review here Torque wrenches tested | Auto Express
For the '04 - '07 models highest torque required is 127 Nm., lowest is 2 Nm. can't see it being much different for '08 onwards so no need to go silly with high end tools.
I have Halfords pro's both half and three/ drive and they are very good. (Down gary, down boy) Sent from Freedom's Hellberry
Yeh 2Nm., starter valve base nuts, to do with the throttle bodies apparently. I'm never likely to touch them. There's a 3Nm. for the cooling fan blade nuts but apart from that get a 1/4'' drive torque wrench to cover 4Nm. to 20Nm. for the delicate stuff.
Being a former car mechanic way back in the stone age, i would buy a reasonable wrench but also you really need two, one that is for the lighter torque range settings and a one that is for the bigger nuts like me. if you tend to use a slightly higher rating wrench on the big settings all the time it tends to become less accurate in the lower range. hence snapping bolts. With a motorcycle small tools with less leverage are always better for judging and avoiding stripping threads etc. Just my experience, maybe I was just a poor mechanic
