Why dont 06/07 crash bungs fit the 04/05?
Discussion in 'Mods, Upgrades, Accessories and Products' started by Muffking, Jul 13, 2012.
  1. Muffking
    Im looking at buying R&G bungs, but the aero style dont start until the 06/07 model and state not for the 04/05. As my 06 plate is an RR5 am i stuffed?
  2. IcarusGreen
    IcarusGreen Elite Member
    No idea but I have the round ones on my 04.
  3. scooby
    scooby Elite Member
    maybe that the fairings need drilling on the 04/5 as the 06/7 are a bit more open?
    if it is that (and cant see what else it could be as the mounts are the same on the chassis) then as long as you dont mind drilling your fairings then you should be fine.
    obviusly this is all theoretical as i'm only assuming :)
  4. BLAGGERS
    BLAGGERS Well-Known Member
    If the engine mounts are the same, they will fit, but ya DO have to drill the fairings on an rr5.
  5. Muffking
    The r & g site also says that the rr6 needs drilling too. The reason i ask is 'cos the rr6 fairings fit the rr5, so why wouldnt the crash bungs?
  6. BLAGGERS
    If they are the engine mount ones I would say they fit, how can they not? I cant see the thread being different?
  7. Muffking
  8. Muffking
    Well I received an email back from R&G today, simply saying that they are not compatible. However, I had already ordered them and went ahead to fit them anyway. And guess what... They fit :-D
  9. bladeian
    bladeian Member
    Look good!, pal im gonna grab some of these was they easy to fit any mod to the fairing??
  10. IcarusGreen
    You have to drill holes in the fairing.
  11. Muffking
    Yeah, as long as you can line the holes up. Start with a a small hole and work your way up so you can make fine adjustments towards where the hole will sit. I find a dremel drill with sanding wheel works best.
  12. BLAGGERS
    Knew they'd fit. :D
  13. IcarusGreen
    I wish I'd waited a few weeks before I fitted the round ones as the aero ones look far better!
  14. Muffking
    Could you add a pic of each side to the thread. I just wanna check that they are in the same position as mine.
