why is my rear tyre is squaring off on the left side ?
Discussion in 'General 1000RR Discussion' started by tgosai, May 8, 2013.
  1. tgosai
    tgosai Member
    Hi,
    looking for a bit of help/advise.
    I have a set of Dunlop sport smart sportmax, ive done about 600 miles and the rear left side is squaring off. im not overly keen on my left bends, so don't think that too much gas on a left turn could be it, the tyre pressure is 36psi, but one thing that does stand out, my suspension is set up fairly soft.
    Could a soft front and rear comp/rebound cause the side to square off ?
  2. jokeshopbeard
    jokeshopbeard Active Member
    Sounds more like this'd be to do with the alignment. Have you checked it recently?
  3. RRdevil
    RRdevil New Member
    Yep alignment issue
  4. Givover
    I would have though the pressure is low ? Should it not be about 42
  5. wedgiewolves#223
    wedgiewolves#223 God Like
    how bad can you get a pic chain too tight , pressures or alignment I'd say also
  6. Si.
    low pressure, camber of the road and alignment.
  7. Freedom of choice
    Left bollock heavier than the right, just a thought....
  8. dave d
    dave d Elite Member
    does it look like this? lol
    #8 dave d, May 9, 2013
  9. blade1980
    blade1980 Active Member
    I run mine at 38 and no problems at all
