Why it's important to get your Suspension set up for YOU!
Discussion in 'Maintenance' started by Remal, Jun 23, 2013.
  1. Remal
    Go for £40 MH racing near Chippenham has changed the bike.
    Why get it set up right!
    Now this is all my opinion and experience
    I found the bike would understeer into fast corners, mainly on track and I wiould feel like i'm going to run off the road/track. After riding the bike it goes where I point it. Huge improvement
    OMFG - Braking. under light braking my ABS equipped repsol blade would dive under light braking, heavy braking. Since being set up it does not dive. the suspension takes the braking and not bottoming out and using the tire to take the force and result in possible underside. or feeling just wrong under heavy braking
    Now the harder I brake the further the front goes down but in a controlled manner that does not dive
    And just for £40
    i'm amazed still. Like having a new bike. And I will be spending my money on suspension now
    Anyone got ohlins Front or rear springs for sale :)
  2. phantom
    phantom Active Member
    yup suspension and unsprung weight mods are the best mods.
    setting up my shocks is something I first wanted to learn about
    when I got into bikes.lucky enough when Mr McCallen sets up a
    bike he brings you in and shows you what he is doing and explains
    it all so in his words you can DIY next time.
  3. Sulby140
    Sulby140 Active Member
    MH did rebuild a couple of months ago on my lads YZF's Ohlins shock, transformed the rear end....would use him again....Mike
  4. Remal
    Good to hear he's done more than a few from this forum. Hoping to get back in the summer to get the front end serviced and uprated a bit
  5. SIDEWAYS
    SIDEWAYS Senior Member
    Mine was set up by Tagg racing, these boys set up race bikes in their spare time as well as run a retail outlet and workshop.
    Mine was done so I can feel the difference between a set up bike and one that is set up standard in the middle if you like.The difference is immense.
    If you have'nt had it done to your bike you will never know what a difference it makes.All these power commanders,quick shifters more power is a waste of money through the twisties if your bike does'nt handle like it should.Everyone are different sizes weights and riding styles.It makes sense to get on your bike set up for you.
  6. BoroRich
    BoroRich Elite Member
    Yay!!! Someone else has seen the light :D
    After getting mine done I became a convert. I realised that I wasn't going to spend money searching for more power. Suspension's where it's at, baby :D
    The place where I get mine done does a fork re-valve and replacement springs for the front sus for less than £300. That's my next job. After that it'll be a WP rear shock.
  7. Black
    Black Active Member
    All this talk of suspension has got me thinking! Maybe my rr05 could do with a refresh. I've never even touched the standard settings since getting the bike new and with the miles now at 32k its prob getting a little tired. Carrying around my 14+ stone incl. leathers, won't help much either eh?
    Does anyone know of any good suspension guys in sunny Scotland?
  8. phantom
    So your preloads are stock too?
    I remember when I first got my RR5 they
    Said the first thing to do was set the rear
    Sag as it was out by a country mile
  9. ddc
    ddc Member
    Probably be this one mate. I'm keen to get mine done too but it's 3 hours away for me. Guess it would be worth it though :)
    Home - ersrace
  10. Remal
    Get it looked at mate will make a HUGE difference
  11. SIDEWAYS
    +1 on that HUGE Difference:)
  12. Scott
    Scott Active Member
    Mct for me
  13. KRL
    KRL Active Member
    Yip, as above, quoted me £90 ride in ride out, about 2hrs to do
  14. thefirebloke
    thefirebloke Elite Member
    That sounds a tad expensive to me, I'm sure the going rate is between £45.00 and £60.00.
  15. Slim Ted
    Slim Ted Active Member
    Do any of you change settings between track and road? My 2012 is still set 'out of the box'. I have done a track day but did not want to mess with settings until I found someone who knew what they were doing!
  16. Remal
    I know people who do but I had mine set up for me and my style of riding. I prefer a firmer ride and just getting it set up right will make a HUGE difference ;) as I said. So you will benefit on road and track
  17. sps170373
    thanks for the info Remal, I might take a ride down the A4 to them! unless anyone knows of a someone closer to Bracknell that does suspension set up work?
  18. julestys
    julestys Active Member
    Hi Guys,
    I have a 2012 Blade with ABS and find under hard braking the bike seems to be twitchy at the rear end.
    Does that mean my front suspension is too soft?
    Not looking to do a track day, just get the bike set up better me thinks.
    Any ideas of best settings to improve everyday riding?
    I live in Stafford so if anyone knows someone in my area that can help set it up that would be great!
    Or should I give the front suspension a couple of turns and play around from there?
  19. Garyb
    Garyb Moderator.
    If you know what your doing, and you know what each turn equates too I'd say go for it.
    Imo it's difficult trying to get a good balance for roads, we have so many different surfaces etc I'd say you have to go for a happy medium, I find my bikes good on some stretches, and not so good on others.
    If in doubt I'd leave it for the pro's mate, perhaps a run over to your local race track and let them whirl the screwdriver, about £50 for a set up? Getting the rebound and sag set up just for your weight could potentially make a huge difference?
  20. julestys
    thank you i will leave to the pros
