Will 2005 wheels fit a2006?
Discussion in 'General 1000RR Discussion' started by Cheggers, Jul 5, 2012.
  1. Cheggers
    Cheggers Active Member
    I am in need of another set of wheels for my RR6 and wondered whether RR5 wheels are a straight swap.
    I am sure one of you knowledgable fellers must have the answer...
  2. IcarusGreen
    IcarusGreen Elite Member
    Should do as the 04-07 blades are the same.
  3. martinowen
    Yes they should do but I would give your local Honda dealer a call first just to make sure
  4. Pinkster1000RR
    Pinkster1000RR Active Member
    Yes they do fit.. as i binned my previous 05 on track and damaged a wheel and replaced with a 06 wheel..
  5. Cheggers
    o.k. cheers for that.
    Looks like they are the same, I will check with a dealer though.
  6. gRRandeelion
    gRRandeelion Active Member
    Front disc rotors are larger diameter on the '06 than the '05, thats the only difference I'm aware of.
  7. viper_biker
    viper_biker Active Member
    Yes, they are a direct replacement. Out of curiosity, whats a set of standard wheels worth? I've my standard ones lying in the garage and wondered what they were worth (they aren't for sale though)
  8. Cheggers
    My opinion (for what its worth, and that's not a lot!) as to the value, a clean pair would be worth 400 but a well used pair half that.
