AS above. I sold to a mate my brand new Carbon king rear hugger and he's tried to fit it on his 2012 blade but unsure if it fits correctly. Anyone know if they are different ? cheers
Don't think it will mate though depends on how it's been made. The 12- on bikes need a larger checkout for the larger canister on the shock.
As above, the shock reservoir is different on the 2012 bikes onwards. I had the same issue. Currently got the Honda one, expensive but excellent fit.
Yep MY2012+ uses new Showa shocks Front & Rear. Also the ABS wires need accounting for at the rear by way of a spacer washer. Nothing insurmountable for anyone with half a brain!
I did the inverse. Put a rear shock from a 2012 blade on my 2009 blade. You will have to cut a rectangular hole in the hugger. Not very easy to photograph .
I don't have the before shot, but this is what it looks like now...you can kind of see where I've trimmed out.
