Woolich ECU Flash
Discussion in 'General 1000RR Discussion' started by Jay Floyd, Aug 21, 2024.
  1. Jay Floyd
    Jay Floyd Active Member
    Hi all, I have a 2020 CBR1000RR-R and it's booked in next Tuesday for a ECU Flash using Woolich after fitting a new exhaust on the blade.
    So I have heard during the flash they can do many things.....
    So I have asked for the following:
    Exhaust Servo to be flashed out.
    Custom map for the exhaust.
    Remove the power restriction.
    Be able to change gearing in the ECU (2020-2021 blades do not have that option)
    Is there anything else i could ask him to do?
    TIA
  2. dgr
    dgr Active Member
    They will only be able to set the ecu to the sprocket sizes on the bike, not give you the option to change them yourselves, unfortunately.
    If you like a quick action throttle you could ask for one of the power modes to be set up with a more direct throttle response. I was offered that when mine was mapped.
