Worn piston rings or something else
Discussion in 'General 1000RR Discussion' started by nick macdonald, Mar 20, 2017.
  1. nick macdonald
    nick macdonald New Member
    I've just changes the plugs on my RR5 (17k miles) after it started to sound very agricultural. 3 plugs fine, one plug covered in dirty oil. So I'm assuming the worst but here's the interesting bit. The bike has always burnt a lot of oil and in stripping things down I noticed oil weeping from the exhaust port with the dodgy plug. Not a lot but enough to make a regular smell. Exhaust clamps have now been retightened although they seemed ok. My question is - could the problem with the exhaust clamp be causing the plug problem. Should I get a new exhaust port gasket ? Or could the problem with the cylinder but causing the exhaust port problem?
  2. blake7
    blake7 Active Member
    Should have done a compression test when doing the plugs to see if that cylinder is low maybe?
