Worried about my tyre
Discussion in 'Maintenance' started by kpone, Jun 2, 2012.
  1. kpone
    I might have, inadvertently dropped a bollock this morning while cleaning my chain. I was using wurth brake and chain cleaning spray and fired it without double checking the alignment of the nozzle and hosed the rear tyre. I wiped it off immediately but it left a brown staining where it hit. I soaked a cloth in isopropanol and worked at it but there is stil a mark there and it started to feel sticky where I was rubbing so I stopped. I was going to try and, carefully, scrub it off but the heavens opened at that point and drove me back into the garage.
    Should I worry about this or, as it was a cleaning agent, not worry about this, do you think.
    #1 kpone, Jun 2, 2012
  2. stevebetts
    stevebetts Well-Known Member
    I would have thought a few miles on the road would sort it out.
    Just keep an eye on it.
  3. Jamiestrada
    Just what I was going to say Steve :)
    I would be surprised if it had caused any damage to the tyre
  4. kpone
    Thanks guys. It just spooked me a bit when the compound changed colour.
  5. Jimbo Vills
    As already said - sure will be fine, but by Christ please take it easy for a good 10 / 20 miles!!
    I'm always amazed at people who have their Scott oilers cranked up and there is oil all over the left side of the tyre.... That would freak me out!!
  6. Givover
    I magage to get some on my tyre nearly every time even with the drapped cloth over both tyre and bottom panel like the boys say clean it and hit the road Jack.
  7. Dave V
    Dave V Elite Member
    Be fine mate, always get chain lube and acf on mine and have had no long term issues
  8. MrB
    MrB God Like
    If it makes you feel any better a while back I reached some stationary traffic so decided to filter, not realising the reason for the hold up was a crew painting fresh road markings.
    By this time it was too late and suddenly both tyres were wrapped in a semi fresh tarmac and white paint coating resulting in a ride Barney Rubble would find uncomfortable.
    Fortunately upon arriving at the destination as embarrassment meant I had to continue after ruining their hardwork the mix began to set and I was able to pick the worst off, deciding a hard ride home should dislodge the rest. Unfortunately in the process showering any following vehicle in sizeable debris.
  9. Jamiestrada
    What a brilliant story :D
    I have the funniest mental picture in my head of what the bike tyres looked like, thanks for sharing
  10. kpone
    My sister had this toy, a little handle that you could fit these rubber wheels into with impressions of bunny rabbits, flowers, dicky birds and the like, that you pressed into an ink stamp and then rolled onto a piece of paper (or the living room wallpaper as she thought).
    I 'spect it looked a bit like that.
  11. JM1
    JM1 Active Member
    A quick burnout would probably sort that out
  12. kpone
    That did cross my mind, but maybe not on the drive.
  13. Jamiestrada
    On your neighbors drive would be the obvious place, a free show of fireblade power and burnt rubber, who could possibly be upset by that :) or any local supermarket car park after 8pm and the boyracers will quite literally wet themselves ;)
  14. kpone
    My only worry is its more the side of the tyre than the face. Hard to burn that out and more likely to cause an unpleasant surprise if it's a problem.
  15. arthurbikemad
    Give it a good wash with some fairy it will be fine mate.
