Would this show up almost every bike?
Discussion in 'Lounge' started by Remal, May 28, 2011.
  1. Remal
    Thoughts :blink:
    VenomGT.com | The Official Website of the Hennessey Venom GT
    Hennessey Venom GT
    Spec
    Performance
    0 – 60 mph 2.5 sec.
    1/4 Mile 9.9 sec. @ 162 mph
    0 – 200 mph 15.9 sec. (Bugatti Veyron = 24.2 sec.)
    Top Speed 267 mph
    Power
    Horsepower 1,200 bhp @ 6,500 rpm
    Torque 1,155 lb-ft @ 4,200 rpm
    Bhp / Weight 767.23 hp per ton or 2.61 lbs / hp
    Engine
    Type V8
    Block Aluminum
    Size 376 CID (6.2 Liter)
    Position Mid Longitudinal
    Compression 8.8:1
    Redline 7,200 rpm
    Forced Induction Twin Garrett Ball Bearing Turbochargers
    Length 15.27 ft. (4,655 mm)
    Width 6.43 ft. (1,960 mm)
    Wheelbase 110.24 in. (2,800 mm)
    Track – Front 63.46 in. (1,612 mm)
    Track – Rear 63.15 in. (1,604 mm)
    Body
    Material Carbon fiber composite except doors & roof
    Weight just over 1000KG wtf
    Mental :hail:
  2. slowr1der
    slowr1der Active Member
    Er yep i guess it would
  3. GSP
    GSP Active Member
    It's been around ages and is a posh Elise with a big v8 stuck in it... It's easy to build a quick dragsters but I'd like to see it go around corners.
  4. dan.1moore1
