1,200hp too tame for you? You need John Hennessey’s new 1,500hp hypercar.. New Hennessey Venom GT2 - BBC Top Gear a few specs of the less powerful car FFS 2013 Hennessey Venom GT Specifications Performance 0 – 200 mph 15.3 sec. (Bugatti Veyron = 24.2 sec.) 0 – 60 mph 2.5 sec Power Power / Weight 1244bhp / 1244kilograms (1bhp / 2.20 lbs) Horsepower Adjustable with 3 settings: 800 bhp, 1,000 bhp & 1,244 bhp Engine Type V8 Block Aluminum Size 427 CID (7.0 Liter) Position Mid Longitudinal Compression 9.2:1 Redline 7,200 rpm Forced Induction Twin Precision Turbo Ball Bearing Turbochargers Oiling System Dry Sump Lubrication Fuel System Sequential Multi-Port Electronic Fuel Injection Transmission Type Ricardo 6-Speed Manual Gear Ratios 2.61:1, 1.71:1, 1.23:1, 0.94:1, 0.77:1, 0.63:1 Final Drive 3.36:1 Brakes Calipers Brembo 6-Piston (all four corners) Rotors 15.0 x 1.34 in. Carbon Ceramic (all four corners) Suspension Type Penske Adjustable Coilover (all four corners) Ride Height Adjustable by 2.4 inches (60 mm) Dimensions Length 15.27 ft. (4,655 mm) Width 6.43 ft. (1,960 mm) Wheelbase 110.24 in. (2,800 mm) Track – Front 63.46 in. (1,612 mm) Track – Rear 63.15 in. (1,604 mm) Body Material Carbon fiber composite except doors & roof Type 2-door Weights & Measures Curb Weight 2,743 lbs (1,244 kilograms) F / R Balance 37 / 63 (empty); 44 / 56 (with driver & passenger) Fuel Capacity 18.5 gal. (7.0 Liter)
