Yoshi R77 Advice
Discussion in 'Mods, Upgrades, Accessories and Products' started by Womblewizard, Apr 21, 2014.
  1. Womblewizard
    Womblewizard Active Member
    Hi, Need advice. I've got a 09 blade fitted with a Yoshi Carbon R77 exhaust. MOT due in a couple of weeks so had some down time and decided to put db killer in. Previous owner fitted exhaust and just pushed it in for the Mot.
    Thought this would take two minutes how wrong am I.
    1st problem when looking at exhaust realised the rubber grommet needs to come out allen bolt goes in holding db killer in. NO hole on the inside! After several attempts hole just needs to be pushed through and with pliers managed to remove (hope this is right) Okay nearly there - place db killer in and aline the holes ARRRRRRRRRRRH
    Problem 2 How far does this to go in close but not close enough. So rather than force it to much decided this would be easier if I take Can off bike and see how close I am and also aid the allen bolt fitment. (Seen on previous threads how difficult this is)
    Problem 3 Getting the silencer off! took the two springs off top and bottom removed allen bolt exhaust bracket to rear sets surely just pulls off...
    Walked away - gave up smoking in October could really have one now. Any advice or am I doing something wrong.
    No wonder previous owner only ever pushed it in what a nightmare........
    Is this just a sh*t job or is it me!!!! :confused:
  2. blade1980
    blade1980 Active Member
    Mine passed an mot with the baffle out, not that this helps your current problem!
  3. sps170373
    I wouldn't bother, my old akra passed without the db insert in no problem my racefit might be a different story
  4. Givover
    As I remember I had to drill out the hole for the baffle and also file an edge off the round bit of the baffle so it would sit in correct.
  5. Womblewizard
    Got the hole so that's fine. Do you file edge of the black collar so goes in a little further. Jesus this is a bad design.....
  6. Givover
    Its a few years since dude so don't attack it until further advice by the boys on here. .I had to file mine on the bottom edge so it fitted but was not seen once insitu .i thought It was just mine and didn't consider others may have the problem .the other thing I managed to do twice was lose the little bolt down the exhaust but this rattled out by shaking the damn thing upside down.
  7. Ratser
    Ratser Well-Known Member
    From memory I was told that it was just a ram baffle that didn't need to be fixed.
    More difficult to get back out.
    That was at a Honda dealership.
    Never had mine in, and TBH never even looked at it in any great detail.
  8. Womblewizard
    Cheers for the advice pulled collar off and checked pipe went in not a problem so must be the collar! Got the angle grinder with a flap disc and took the surface off. HEY PRESTO all lined up!
    Now got to put screw in, do that tomorrow don't want to push my luck!
