Hi guys, took delivery of the yoshi r77 today, and i,ve punched out the hole to accept the baffle, but the baffle is a right squeeze to get in.... any tips??? Also, where can you get a bs standards sticker from, and does the "closed circuit" sticker come off easily...i don't want to fek it up! churz!
If you are struggling with that baffle mate, I can modify it or make you another one. Got any pix and dimensions?
Megawatt... cheers mate. Ill dremel the lip left behind by the metal tab to smooth it out a bit. If it doesn't work, i'll call on your services. Cheers Colin...all ordered mate from that link you sent me!
Si the baffle was tight when I fitted it to my Yoshi R77 for my TD. Just took a belt sander to the edges and it was fine. you don't notice it when fitted. the can was it from the US? mine is and has nothing on. And only fit the baffle when you need IE Track days
Yeah, from Bio hazard. Theres a plate with a sticker underneath saying closed circuit use only... well...there was.
As I said just take a belt sander to the baffle and it will fit just right. BUT BIG BUT be careful when fitting the bold to it as if it drops in the void between the baffle and outside its a right fecker to get out
mine was from bio hazard but never had any labels/stickers attached. my baffle was and still is tight. slowly tapped it in with the wooden handle of a mallet. only way to take out was remove can and push back out. will adjust to fit soon. they do sound sweet!!
Oh I didnt realise that the baffles would be so hard to get in and out....ill be using mine on the track so need them to be easy to fit and take back out. Might knock you up Si for some instructions
it's not difficult after you sand the sides a bit. only just a bit tight so rather than hammering it in it fit better owww errr
Once its gone in and out a few times it loosens up a bit... oh errr! The best bit about the baffle is watching it turn gold when it gets hot! It freaked me out a first, goes in black, TD and Brands, then came out gold?!
Havent got mine yet, but thing Si posted his was about 25 quid. I bought the full carbon one that was about 460 I think, so hopefully 490 ish all in
