I put the baffle in yesterday, and lo and behold, the bolt that holds it in fell between the sleeve and can I fitted the baffle using another bolt, but other than taking the can off to get the one that fell in, is it ok to leave it in between the sleeve?? I.E it can't go anywhere and break anything? cheers!
Take it for a blast gun the life out of it and it will be gone. I did the same, dropped a bolt in doing the baffle. Then got called away, then forgot about it, weather was crap and I didnt ride for ages. Then went for a spirited ride. Halfway through I remembered what had happened. I then took it all off, and there was no sign of it at all, anywhere.............................although I didnt check the flux capacitor
