yoshi r77 question
Discussion in 'General 1000RR Discussion' started by stevet, Dec 22, 2014.
  1. stevet
    stevet Active Member
    have been reading the 2014 blade has different sized link pipe diameter from 2012,2013 bikes....will i have too get a yoshi r77 specific to the 2014 bike
  2. Buckmeister
    Buckmeister Active Member
    Yep, unless you change the headers too. The CAT is now part of the headers and has a 60mm diameter outlet (about 10mm bigger than previous models).
    Also the Lambda sensor is now mounted in the headers, near the CAT so no mounting boss required in the link pipe...
    It is possible that Yoshi make a link pipe to suit 2014 models that still fits the older can ???
  3. stevet
    oh right.....thanks for info.......could have made an expensive mistake there
  4. Buckmeister
    Sure could !
    Not that many options out there for 2014 models and adapting a pipe from an earlier model could be done but it's a lot of work and the bends aren't right causing things to clash a bit !
    Trust me I looked at it but it would have been too much work and would probably look a bit shit in the end...
  5. stevet
    narr.....carn't have em lookin shite...against the rules
  6. Buckmeister
    Racefit all the way !
    Loud but awesome fit / quality...
  7. Great Guy
    Great Guy Well-Known Member
    You need to take those pillion pegs off.
  8. Rented
    Rented Active Member
    I did make that mistake. I was highly pissed off at the retailer from the US that I felt should have known, but he said that Yoshi hadn't told him either and he sold it to me in good faith.
    I suspect but I am unsure that the bracket that holds the can onto the mount point on the rearset may be different as the footpeg was moved 1cm back. Therefore the Yoshi pipe is a different part number, whereas similar Akras which use a carbon fibre sling which can move are the same part number for both the 12-13 and 14 models.
    #8 Rented, Dec 23, 2014
  9. stevet
    Jeez....didnt know about the rear set either
  10. sps170373
    Looks good mate, looks better with out the pillion pegs though
  11. Beefcake313
    Beefcake313 Active Member
    Have you had that through a noise test yet on a trackday?
  12. Buckmeister
    Would do but I need them for me biatch !
  13. Buckmeister
    No, this bike won't be going to the track, have a project bike for that, saying that I think it'd be boaderline at best !
