Just fitted it and it looks and sounds great however...... It is very close to the swing arm, if I sit and bounce on the bike it doesn't make contact but as I say it is very very close. Is this the case with this particular exhaust? There doesn't seem to be much adjustment available . On another note How did you guys manage to line the heat shield up with the belly pan? Mines not exactly right but isn't bad either but was wondering if there's a knack to it? Cheers
its only close when its on the side stand,normal riding its miles away,get someone to sit on the bike you'll see. if your infill doesnt line up its due to the link pipe not on correctly ie needs twisting,however this then moves the can, best bet is to loosen hanger bolt,slack off infill bolts where it bolts to the frame and fairing, undo clamp on header pipes twist the link 'S' so the infill lines up with fairing. once lined up tighten clamp and fixing bolt then twist adjust the end can for best clearance then tighten hanger bolt. hope that makes sense?
Thanks for that, it went on but maybe I expected it to line up perfectly cos that's the way I am haha My mate sat on it and bounced about and yes the gap does open right up Obviously a very high precision fitment that I'm just not familiar with
