Anyone know if this would fit with out too much messing around with a akrapovic end can as looks similar to yoshimura can. Thanks Luke https://www.ebay.co.uk/itm/153912840554
It may fit with a bit of modification. The link pipe may be a bit too bulky for a snug fit, also the cut out for the silencer may be slightly in the wrong place. Maybe someone on here has that combination already and I’m sure they will come along and let you know. I had real trouble trying to find a good infill panel, after spending £65 on a piece of plastic rubbish I ended up making one.
If you’re any good at fabricating you could give it a go. I used a piece of light aluminium plate I got from Screwfix, bent it into shape and lined the inside with glass fibre to strengthen it. I also attached a couple of lugs at the glass fibre stage to attach it to the bike. After I was happy with the shape and fitting, I skimmed it with filler, smoothed it out and painted it. For me it was a long process of trial and error and took way longer than I had anticipated, but worth it in the end.
