Hi I have just fitted an yoshimura exhaust to my blade, but there isn't a screw hole for the o2 sensor. What is best for me to do? Its plugged in at the minute but i cable tied it up out the way. thanks
Reckon your gonna need an o2 eliminator otherwise you'll have problems! Speak to Navvy as he has a yoshi so does Remal
ive heard you can make your own with a 330 ohm resistor cant seem to find an eliminator on ebay in the UK
i purchased mine off ebay, it had been re conditioned with a new sleeve and tip. For all I know the link pipe could be a different manufacture. I didn't know this at the time of purchasing. The daemon tweaks web site dont sell a resistor for the CBR1000rr, im going to buy a 330ohm resistor and bridge the two white wires ecu side, that should do the trick.
I've installed a 330ohm resistor and haven't any FI codes or running issues so far Hopefully it's all good Here is a picture, I've since wrapped the plug in tape to water proof it.
