yoshimura r77 exhaust
Discussion in 'General 1000RR Discussion' started by tony lomas, Nov 25, 2015.
  1. tony lomas
    tony lomas Member
    Hi looking at getting a yoshimura r77 exhaust for my 2010 blade apart from the looks and sound has any one found a difference in there mpg cheers tony
  2. Carl
    Carl Well-Known Member
    I put this exhaust on from new so I can't help with the MPG, however I have achieved 168 miles on a tank?
  3. Voleracing
    Voleracing Active Member
    Hi Tony the slip on r77 makes zero difference to mpg. How far you twist the throttle round makes the biggest mpg change ;)
  4. tony lomas
    tony lomas Member
    Cheers carl I got around the same mpg with the standard one think it's time for a change. It'll sound amazing with the quickshifter that I've just had fitted
  5. tony lomas
    tony lomas Member
    ha your right there
  6. Slick
    Slick Elite Member
    Yes, but I'm using a wideband sensor on the yoshi, so generally I'm running slightly richer than the stock map.
    Only a few mpg less though, still get 3 commutes to a tank which to me is the important thing.
    The howl is worth it though!
  7. tony lomas
    tony lomas Member
    Definitely getting one can't wait
  8. jonty
    jonty Active Member
    Got this on my 2010 blade Yoshimura r11 sounds Bob on and god knows what the fuel economy is like image.jpeg
  9. tony lomas
    tony lomas Member
    That looks the dogs b@llocks
  10. Mr OCD
    Mr OCD Well-Known Member
    Fuel economy drops quite substantially once it's mapped properly for the R77 ... With no map and using lambda shouldn't make any difference but will run lean lower down ... Mapping makes a big difference.
  11. tony lomas
    tony lomas Member
    Ok cheers for that possibly need a pc5 as well
