Yoshimura r77
Discussion in 'Mods, Upgrades, Accessories and Products' started by kidder1000, Jun 24, 2013.
  1. kidder1000
    kidder1000 Active Member
    Here are some photos of the install but would appreciate some info from members who have also installed this exhaust-
    1. Could not use the stock hanger screw as per instructions, I used the longer one that came with the kit but not enough room on other side to put on the securing nut but it seems secure enough (photo 1)
    2. I put the aluminium spacer that came with kit on right side of hanger but pipe still comes very close to swing arm- about 1.5mm, is this ok? (photo 2)
    3. I followed the servo motor cable from original exhaust to under the seat and released it from the round servo, as per yoshimura instructions I marked where the cable originally was and returned it to that position, but when I went out for a test ride and came back and looked at the servo position it had moved a quarter turn? (photo 3) Should I now move back so white marks align? WHAT DOES THIS CABLE DO?? CAT??
    4. This thing came with kit, it looks like something religious people would torture you with after admitting that you went to Amsterdam for a weekend! I didn't use it- any ideas?? (photo 4)
    I WILL TRY AGAIN TO UPLOAD PHOTOS BUT ITS A WASTE OF TIME, you shouldn't have to go to a photo barn etc to upload photos who is running this site???
  2. navvy10
    navvy10 Well-Known Member
    Can't you just click on the pic image in the toolbar and just add each photo and upload? Works ok for me
  3. explorer
    explorer Member
    Can looks great, you need an infill panel to finish it off.
  4. navvy10
    1 and 2 are similar to mine. You can twist the back box slightly to get a couple more ml but nice and snug and mine had never rubbed once as they move together ;)
  5. navvy10
    Isn't item 3 to operate the flap in the exhaust to assist torque on the stock one?
    Item 4 totally agree!! Wtf would you ever use that nasty little item for??
    And yes pic 5 show no Yoshi panel which I would highly recommend although I don't know how it's supposed to fit flush with the spacer mounting bracket they provide you with??
    Sounds amazing tho doesn't it!! Very distinctive sound and apparently the number one selling aftermarket exhaust in the uk! So there's a few of us out there :D
    #6 navvy10, Jun 24, 2013
  6. Pete1987
    Pete1987 Active Member
    Item number 4 is for pulling the springs back when assembling the pipe.
    You need to make sure the servo goes back into the the standard position otherwise the Fi light will come on.
    I have a yoshi. Epic doesn't even come close to the sound it makes!
  7. vvtr
    vvtr New Member
    some guy at ponderosa tried to flog me one of these the last week but i'd just bought the racefit.
    he wanted too much for it anyway imo but it was the full system.
    btw - the hanger nut!!!!! locktite the fker.
    if you lose that while youre ait and abait your fuxed! (dont ask!)
  8. Ratser
    Ratser Well-Known Member
    Nice can mate.
    I got mine taken off my old bike and at this moment it is being fitted to my new one.
    Can't wait to see it on that beast.
    And not being at all handy or mechanical, I left it to the experts to remove and replace.
  9. kidder1000
    no by past experience 20 yrs the professionals u CAN NOT TRUST THEM could be an apprentice working on your brakes thinking about his girl who he is taking out that night- the old saying if u want something done correctly DO IT YOURSELF! that's how I fly
  10. kidder1000
    thanks for info, will locktite the bolt :)
  11. Guymx
    Guymx New Member
    I used the stock hanger bolt and the can fits near perfect!
    Instructions could be a lot clearer but after a few try's it went on lovely
  12. Guymx
    Guymx New Member
    Sexy!!!!
  13. navvy10
    You are now one sexy sounding mo'fo!! :D
  14. Ratser
    Mine sounds louder on the new blade than it did on the last one.
  15. dogman
    dogman Member
    Mine arrived yesterday with PC5, just waiting for oxygen sensor eliminator then its all systems go.................
  16. Dave-RR
    Dave-RR New Member
    On mine I just disconnected the cable and all was good, no FI lights it still moves cause its plugged in.
  17. dogman
    dogman Member
    I think you mean the flapper servo cable
    I meant the cable to the oxygen sensor in the OEM exhaust, which I am not using because I will be fitting the PC5.
  18. Guymx
    Guymx New Member
    Let me know if the PC5 makes £275 worth of difference, not got one yet
  19. Carl
    Carl Well-Known Member
    I would also like to know, I'm fitting my yoshi next week!
