Zip replacement
Discussion in 'Lounge' started by blade1980, Apr 18, 2015.
  1. blade1980
    blade1980 Active Member
    The zip has given up the ghost on my 1 piece leathers, can these easily be repaired/replaced?
    Guess it's a specialist job really ?
  2. Barstewardsquad
    The zip itself or the puller? You can get things to fit to the puller if that is all that is wrong, but if it is the actual zip you will need to talk to someone who can fix leathers.
  3. blade1980
    Yeah it's the actual zip that's had it and needs replacing,
  4. exuptoy
    exuptoy Elite Member
    I had the calf zip replaced on my old one piece this week. My mam did it (she is a seamstress and alters clothes for a living). She doesn't usually do a lot of leather stuff as it can break the plate on the machine as it's not really the correct machine for the job.
    I was quoted £22 at the local bike leather repairers in the market but they were off on holiday so my mam sorted it! :)
    Just check your local listings online.
  5. Muffking
  6. blade1980
  7. blade1980
    Thanks mate. A few other people have suggested him as am I'm not far away I'll give him a call in Monday, hopefully he'll sort me out, can you remember how long the turnaround time was ?
  8. rewy..rr
    rewy..rr Active Member
    Got quoted £60 recently to replace zip on my Wolf leathers. Top zip works ok, but bottom zip won't pull up, bit of a job to do a pee, but for £60 will put up with it
  9. blade1980
    Not really bothered what it costs, the suits useless without it!!
  10. Mike07
    Mike07 Active Member
    D.P Leathers
    • Tel: 0191 2324450
    243a, Westgate Rd, Newcastle Upon Tyne, Tyne And Wear, NE4 6AE
    I believe This guy is well thought of ( I've not used them personally).......... but some postage would be in order.
    Mike.
  11. Muffking
    Yeah it was something like around 3 or 4 days.
