GoPro mounts - Show us yours!!!
Discussion in 'General 1000RR Discussion' started by Muffking, Dec 30, 2013.
  1. Muffking
    Having been round the houses with camera mounts last year, I am now the lucky owner of a GoPro at last (lucky as it was an xmas present).
    So those of you with GoPro's, I'm really interested in where your mounts are as I've ordered loads of different types and hope to get cracking with fitting them to both bikes when they arrive.
    I'll start the ball rolling with what I have done so far.
    Suction mount on the nose of the Blade. Just thought this may make for a decent shot if it stays on.
    Helmet. Just waiting for the correct adaptor so the camera faces forward.
    Tail of the track bike, a pretty common place,
    although I had to drill a hole in the mount for the tail section bolt.
    Will also add one to the Blade when the mounts arrive (without the hole of course).
    Anyone else?
    I know Wedgie, Alan and possibly GaryB and Colin have GoPro's, so would be interested in seeing your mounts.
    Also Wedgie, did anything break on yours when it came off the R6 at Cadwell?
  2. Remal
    Mounted mine on the right hand side on the nose and the results came out like this
    best place I have mounted it and i've put it on the front, back sides etc but loved this mount
  3. ColinBR
    Here's mine
  4. Scott
    Scott Active Member
    Anyone on the yoke. ?
  5. IcarusGreen
    IcarusGreen Elite Member
    I've had mine on the suck on mount on the tank so it sees the speedo and came out well.
  6. sinewave
    Me too, but mines a Drifty Ghosty one!
  7. Tifa
    Tifa Active Member
    Fer chrissakes...don't rely on those sucker mounts!.... if you have to use one, make sure you back it up with some tie grips or nylon string, just in case.
    Also, if you are tying your camera to the bike, make sure that if it comes off, it can't get itself snagged into the front/rear wheel/chain etc...
  8. sinewave
    Lock wire mine on to the steering damper mounts.
    Worst it can do is flap about and scratch me Tank paint if the sucker comes loose! ;)
  9. lambchops
    lambchops Elite Member
    mine goes on the tank, no chance of this one coming off, made of 3mm alloy and bolted down :)
    • Like Like x 6
  10. Muffking
    Cheers guys, keep 'em coming, especially any behind the screen.
    I may also go with Colins idea using the stick on mount for the nose. Its more secure and i can still get the angle right.
    Got these to tether, just in case.
  11. el-nicko
    el-nicko Well-Known Member
    1" ball on the top yolk and cable-tied on and Tom Tom suckered to the tank. ;)
  12. sinewave
    Kinnell Nicko!
    You've been 'sulking' along time since ya Bollocking! [​IMG]
    Welcome back matey! [​IMG]
  13. sps170373
    Nice to see you back el-nicko
  14. AOS
    AOS New Member
    Great vid Sin
  15. Remal
    I used these at Donny and they saved my go pro. it feel off and hung on with these.
    lamb where did you get that tank mount? or did you make it yourself?
    Ello Nicko hope you had a good Christmas and good to see u back mate
  16. Hondaboy63
    Hondaboy63 Active Member
    I've had bad footage with vibration. So I have gone for the least attachment image.jpg
    I got a bracket made and it is excellent.its on the original fairing bracket.
    Simple and easy done.
  17. Remal
  18. Beckers
    Beckers Elite Member
    Ditto, got some really good footage going over The Mountain at this years TT
  19. Muffking
    The mounting bits are starting to arrive by post now, so here's a finished shot of the helmet mount as I wanted it to be more discrete that being mounted on the top.
    I am also working on an RR4-7 HESD mount and will upload a photo in a few days.
  20. ColinBR
    You may find that it will pull your head to the side when the speed picks up.
    #20 ColinBR, Jan 5, 2014
