headlight
Discussion in 'Maintenance' started by Matt7247, Apr 24, 2024.
  1. Matt7247
    Matt7247 New Member
    hello folks, My headlight keeps blowing, 2004 model. I recently changed it, and it was fine for a few days, but then today it was popped, the main beam/pass beam are all fine? Bike starts ok, runs fine and I have indicators etc.
    Has anyone got any simple suggestions, I did notice that the headlight fits into a unit, which the cables are attached too.
    May sound daft, but its all new to me.
  2. Broadie
    Broadie Active Member
    Did you touch the glass of the bulb with your fingers. Oil from fingers will burn on the glass causing a hotspot. Otherwise a bad connection.
  3. Matt7247
    Matt7247 New Member
    Hello mate, i didn't think so, but then there is a big possibility i did. I have changed the bulb, and made sure there was no grubby prints on it, so ill have to wait and see :)
  4. bonjo
    bonjo Active Member
    also check the regulator voltage accross the battery. High volts blow bulbs
