Hi folks, I brought myself some flush fit led indicators from 2 LED Motorcycle Turn Signal Indicator Light Flush Mount for Honda CBR 1000RR | eBay I have a couple of questions if you can help please, I know I need to change the relay to sort out the flasher time, but there are so many on eBay I don't which one to get? Also where is the relay located on an 06 blade please? Also, I know this has been covered a fair bit but, on my triumph I had some shorty Pazzo levers and they felt good. As this is my first sports bike, whats the general preference/experience to lever length on the blade? I know it varies on personal preference too, but any recombination would be appreciated! I'm either going to get Pazzo's again or some ASV's once decided on length. Again any recommendations would be great on which are the better one's and where to get a set, unless somebody has some for sale on here. Thanks!
This is the relay I fitted to my 07. If you have hazard lights you need a 4 pin relay. You can fit inline resistors instead but I don't like that option as they produce a fair amount of heat. On a 06/07 the relay is located behind the left hand fairing as is easy to get too, in fact as you are fitting the indicators to the front you will see the relays when you remove the fairings. Weren't you also looking at a Gear Indicator? If so the diag plug used by the GIpro etc is located in the same place, easy chance to kill 2 birds with 1 stone.
