  1. Slipps
    Slipps Active Member
    Made and fitted my own full length Radiator guard.
    • Like Like x 9
  2. Hedges
    Hedges Active Member
    Been a good day!
    Rear pegs removed and carbon frame protectors fitted :)
    Now to get the Metzelers fitted and that's it for a few weeks lol
  3. MPJ
    MPJ Active Member
    Nice bike ! So is that a 2012 ?
    Trying to get my head around the TT editions...didn't they change the design in 2013 to the more tri-colour style ?
  4. Hedges
    No buddy, it's a 2014.
    The bike was resprayed by the Honda dealer on delivery at the previous owners request.
    Think you're right, they did change to tricolour at some point.
  5. Bradley
    Bradley New Member
    Fitted my heated grips with modified and painted bracket and stainless bolts.
    Fitted a Scottoiker e-system.
    Fitted my zumo 550 mount and wiring.
    All in prep for mine and my dads ride to my uncles villa in south Spain, canny wait!
    I wired all the grips and sat nav through a 5 pin relay using the number plate light as the trigger, I also wired my optimate plug through the normally closed pin on the relay, so I don't blow it off the wall if I start the bike with it attached.
    The sat nav supply is wired through the relay to a 12v DC female 2.5mm plug up near the headstock, so I can plug it in or remove the whole assembly in seconds.
  6. Lozzy
    Was all set for a sunny evening ride out & my Friday night spam fritter & chips......then dropped it on the driveway :oops:
    Foot peg fooked & scuffs in usual places.....the saving grace was the good old gb covers did their job!
    Good job I've a full bottle of JD & a box of tissues :(
  7. Dave dunlop
    Dave dunlop Elite Member
    Finally got mudguards back from the painters!!!
  8. MPJ
    MPJ Active Member
    Stunning Dave !
    Was that wicked coatings ?
  9. Dave dunlop
    Cheers Max was going to catch up this week as I've just finished a few projects and been mega busy, A good friend of mine that owed me a favour or two ended up painting them for me! Result...
    Weather looking good over the next few weeks so will give you a tinkle for a catch up and ride :)
  10. MPJ
    MPJ Active Member
    Look forward to it:)
  11. TrackDayT5
    TrackDayT5 New Member
    Oil and filter change found out that the previous owner had put the oil filter on with about 10000nm of torque.
    used the bolt at the top to hammer a screw driver through then used a ring spanner with the screwdriver to lever the tension off it !
    forgot to order a new sump plug and washer so just threw the old one back on :D
  12. Muffking
    Whipped the spark plugs out due to some slight hesitation at low revs.
    How do these look?
  13. Manofsteel
    Manofsteel Well-Known Member
    New asv levers on just waiting for akropovic that's just been ordered starting to look and feel more like my bike now image.jpeg image.jpeg
  14. Reddevil007
    Reddevil007 Active Member
    Fiddled and adjusted the suspension settings. Took her for a ride and much nicer now for the road
  15. Bobzilla
    Bobzilla New Member
    Gilles chain adjusters, K&N filter, PCV, LED map switch, new brake pads. And discovered that you really should do everything on a rear wheel in a logical order, in case you forget something rather important, like tightening up the rear axle. :eek:
  16. TW4T50N
    TW4T50N Active Member
    @Dave dunlop, have you got a photo of the entire bike? The front and rear guards look mega, can only imagine what the rest look like!
  17. dessp2
    dessp2 Well-Known Member
    Dave, do you lube your chain or just clean it after each ride? WD40 on a clean rag seems to do the trick for me.
  18. Dave dunlop
  19. Dave dunlop
    GT85 or WD after every ride, Then Wurth Dry every few rides:D works for me!!
  20. TW4T50N
    Need to upload a photo of the whole bike with the repainted guards.
    Absolutely stunning bike mate, jesus.
