  1. si1000repsol
    Fitted the stock Repsol tank cover and fitted gold anodised titanium bolts.
  2. pete954
    pete954 Active Member
    Replaced my Racefit Black Edition titanium can for a carbon fibre one. All new packing and riveted together. Change is as good as a rest as they say [ uploadfromtaptalk1448648375865.jpg uploadfromtaptalk1448648415571.jpg
  3. pete954
    Added a bit of bolt on bling. Thats just about all visible fastenings now changed for delicious titanium. Gotta be worth 2 seconds a lap. uploadfromtaptalk1448731533561.jpg uploadfromtaptalk1448731558487.jpg uploadfromtaptalk1448731604587.jpg
  4. Andrew Penson
    Andrew Penson Member
    I've got to wait until March. What was the weather like, might try this time next year !
  5. Andrew Penson
  6. Andrew Penson
  7. derchef
    derchef Well-Known Member
    New master cylinder , reservoir and levers
  8. Andrew Penson
  9. Great Guy
    Great Guy Well-Known Member
    Went for a ride to test my NEW Oxford HEATED grips. Brilliant.
  10. Andrew Penson
    That's great, Great Guy. Can't take mine out to test at the mo, in bits. Waitng for the posty to deliver tail tidy.
  11. DF!
    DF! New Member
    Just fitted black shorty levers, smoked integrated rear light, removed rear pegs and put on Hotbodies tail tidy. Temp wired the plate light, anyone know what connector I need to fit to the stock loom? Don't want to scotch lock or cut into the original loom....
    7x5 'show' plate should arrive this week, then just got to get to the flasher relay and i'm ready for the summer! tick tock tick tock.. :confused:
  12. sps170373
    I bought a damaged second hand rear light and just cut the connector off that and heat shrunk it to my aftermarket light
  13. Slick
    Fitted new pads and boots (scrubbed them in yesterday - scary as hell)
    Today nearly taken out by an Addison Lee taxi, was a close one, not joking but his bumper scraped my jeans.
    Only cat like reactions saved the day (patted the tank and ABS as a thankyou)
  14. pete954
    Finishing touches added to my new carbon Racefit ☺ uploadfromtaptalk1449088274602.jpg
  15. trueuk
    trueuk Active Member
    fitted a carbon tank cover and a new fuel cap
  16. pete954
    Replaced the front sprocket with a 17 tooth Renthal item. Split the chain and gave it a good clean and riveted it back together. Gave her a damn good clean. May have patted the tank once or twice ☺
  17. Greco
    Greco Active Member
    How did you split the chain mate? Any particular kit you used before and recommend?
  18. pete954
    I have a DID chain splitter/riveter. If your chain has a soft link you can press out the pins and split it but you do need a spare joining link to replace the old one. Without trying to sound patronising it's probably not the kind of job to do if your not sure what your doing. Take a look on you tube, there are probably loads of 'how to' videos on there. Also be careful if you end up buying a chain splitter/riveter, there is a lot of junk out there.
  19. pete954
    Put the Racefit back on and reloaded the map. Almost forgot how loud it is uploadfromtaptalk1449411226925.jpg
  20. si1000repsol
    Fitted the tail back on provisionally after the vinyl wrapping. Also fitted a new hollow m8 titanium bolt for the number plate bracket.
