  1. Blade runner 1
    Blade runner 1 Elite Member
    Hel brake lines fitted. Callipers and rotors cleaned, Motul RBF600 pumped through the new arteries.
    • Like Like x 10
  2. Muffking
    Respray and tart up the lower fairing while it's off the bike awaiting a new rad as they get peppered on track.
  3. mk3golfcab
    mk3golfcab Elite Member
    Looks good Gary, did you do it yourself?
  4. Muffking
    Thanks. Yeah it's just a spray can job with loads of stickers I had lying around.
    It came off looking peppered up the front and with a large scratch down the side where I caught it unloading off the trailer. Not a mint job as I didn't spend too long sanding it down, but I did a few fibreglass patches on the inside to strenghten it up a bit and then just bought a Halfords spray can & lacquer.
  5. mk3golfcab
    Looks good from here mate, well done!
  6. BladeOfGlory
    BladeOfGlory Active Member
    MOT and new boots today. Passed without even the usual "exhaust loud" advisory!
    Metzeler M9RR felt lovely on the 10 or 15 miles home (dodging rain clouds). Need to get them scrubbed in but it makes such a world of difference to the feel of the bike going to fresh rubber from slightly squared off ones
  7. SimonRR
    SimonRR God Like
    Changed the spark plugs, air filter washed re oiled and changed engine oil and filter, now bring on the good weather :D
  8. blink
    blink Well-Known Member
    refitted my refurbished forks, changed some bolts and rode it!
  9. 1000rrboyjay
    1000rrboyjay Active Member
    #11329 1000rrboyjay, May 30, 2021
  10. Selmer50mark
    Rear end strip clean and lube suspension bearings on the RRV 20210526_203100.jpg 20210530_114952.jpg 20210530_142803.jpg
    I think that is the
    First time that swingarm has been off o_O
    Bearings still had plenty of grease in them
    • Like Like x 11
  11. raphael
    Fitted this hel master to go with there new calipers
  12. Boothman
    Had its MOT today - no issues so that’s me set for the next 12 months. Just need to put some miles on it now
  13. raphael
    Pfm fully floating discs and abs pads to go with the hel calipers and master cylinder
  14. jokeshopbeard
    jokeshopbeard Active Member
    Lucky bugger. I got a set of PFM flat/drilled discs (not iron) waiting for me back home to slot onto my BST Tek 5's with Brembo GP4-RX Calipers and pads to match his discs. Gonna be face peeling, I'm sure, in that way only really good brakes can make you feel.
    Spoke to the guy that owns the company for a good hour from here in the states when I ordered them; the man is a true and fine engineer for sure!!
    Might upgrade to his six-pots at some point, already got a brand new set of Brembo M4's boxed up. Along with my lightly used GP4-RX's for sale I might be able to justify the sexuality/price of his calipers...
  15. jokeshopbeard
    BTW, do you think it would be possible to anodize that disc retaining ring of his design in red?
    I've been mulling it over but haven't looked deep into the material/possibility...
  16. dern
    dern Well-Known Member
    I fitted a 520 chain with -1/+2 sprockets…
    And fitted a healtech quick shifter and tested in as unsafe way as I could devise…
  17. Muffking
    Seems pretty well set up to me. Should work on the down shifts too.
    Can't see the chain from that angle though, would be good to see how much the chain flexes as the load changes.
  18. dern
    I imagine the chain was jumping around quite a lot as there was no load on the rear tyre. That's why I kept the speeds modest, I didn't want to knacker the new chain or embed myself in my van.
    How would it work on the downshifts on a 2007? There's no way to control throttle blipping.
  19. Muffking
    I could be wrong, but I thought the QS cut the revs on the downshift too, although I seem to remember reading about a Healtech blipper which adds to the QS.
    If I'm wrong then it may be because I have a slipper clutch and haven't noticed any issues with the clutches downshifts.
  20. 1000rrboyjay
    6D3310F2-F1B8-4587-86A7-15D16E41CE30.jpeg Has anyone else removed standard mirrors for barend ones? I love the look of no mirrors but need to know what’s behind me in case it has the ability to issue tickets haha. Also need to think about indicators. I’m about to road test so I’ll find out shortly..
