Help to get solve sc57 wont start
Discussion in 'General 1000RR Discussion' started by Yomka, Feb 4, 2024.
Tags:
  1. Yomka
    Yomka New Member
    So as you are much smarter man about this all, one more Q, now when i start engine its start harder, can it be from that i lost clutch sensor so now im starting it without it, before when i tear it down i got it installed.
    ALSO got some motor ticking sound, can hear very good about 2-2,5k rpm any thoughts?
  2. Boothman
    I’m not smart at all - I don’t understand what you mean for harder start - sounds like we need another video.
    Try to get the rattle on the video too but the camchain/tensioner are going to be prime suspects at a guess.
    What mileage has the bike done?
  3. Yomka
    Yomka New Member
    dont wanna start right up need to hold longer starter.... when starting first it make small pop and after that only starts, about video later ye sure, and sounds comming from head, valves maybe
  4. Saqib
    Saqib Active Member
    Sounds like you need to check the timing.
    Align the crank to TDC, and then check the cams are in the right position.
  5. Yomka
    Yomka New Member
    Before i tear it down for valve adjustment cam position was same as now, its in correct way and there is all good.
  6. Yomka
    Yomka New Member
  7. Yomka
    Yomka New Member
    any ideas?
  8. CharlieR85
    CharlieR85 Elite Member
    Looks and sounds well in need of attention mate. Don't think anyone will tell you over the Internet what that is for certain.
    #48 CharlieR85, Feb 14, 2024
  9. Yomka
    Yomka New Member
    i mean i have paranoja with this knocking sound, last what i got is chain wear, when i take pic for camshafts i think motor chain is little bit worn, because it dont fit perfect with all marks for camshaft vs clutch cover T mark
  10. CharlieR85
    Start with that then mate. New cam chain, new tensioner and re-check valve clearances.
  11. bill.haze
    bill.haze New Member
    the ticking comes from the camshaft sensor, remove it, take a look at the tip. If you find drag marks on the tip, you know where they came from.
    Just use 2 washers to give it more Space.
    Let me know if you find something ✌️
