I have seen the light
Discussion in 'General 1000RR Discussion' started by megawatt, Mar 11, 2012.
  1. kpone
    What? Built into the bike itself?
    Well I'll beef ucked. What'll they think of next!
  2. gixerthou
    gixerthou Active Member
    maybe some one will think about putting an engine into it ?
  3. Andrew
    Andrew Active Member
    All I can say is i'd rather walk or take the car!
  4. gRRandeelion
    gRRandeelion Active Member
    I think it needs a Repsol paint job to start with!!!
  5. Remal
    Lol at the replys
  6. kpone
    Spotted!
    Megs out on his new bike
  7. Jamiestrada
    Aggggghhhh my eyes it burns, it burns lol
  8. megawatt
    megawatt Well-Known Member
    Some more pix and a vid for more piss taking from you road rocket jockeys. don't you watch Sons of Anadin???
    Well cylinders been soaked in WD40 for 3 days, so took ignition /alternator cover off today and very slowly turned crankshaft. No scraping grinding noises and nice n free moving. No wiring loom , so attached car battery to starter and spun it over. sounds good without plugs in. Next job is replace battery box with reg/rec, starter solenoid and coils attached and try to start the beast!!!
    Some pix;
    Engine with all 4 plugs removed.
    ignition/alternator cover off to access 17mm crankshaft nut.
    Spinning motor with plugs out and car batter direct to starter motor.
    Short vid. Forgot I still aint got wiring loom etc.Double click on piccy.
  9. kpone
    You mean it looks that bad and doesn't run either!?!
    Do you fancy buying some magic beans.............?
  10. megawatt
    Got some thanks mate. swapped em for a Fireblade. BARGAIN!!!
  11. kpone
    I wouldn't have been so cruel about it if you'd said you'd bought it as a garden ornament.
  12. megawatt
    Now there's an idea?
  13. gixerthou
    so you mean that it is meant to move ?
    i thought you where just weighing down the driveway
  14. megawatt
    You people can be so hurtful!:(
