Some more pix and a vid for more piss taking from you road rocket jockeys. don't you watch Sons of Anadin??? Well cylinders been soaked in WD40 for 3 days, so took ignition /alternator cover off today and very slowly turned crankshaft. No scraping grinding noises and nice n free moving. No wiring loom , so attached car battery to starter and spun it over. sounds good without plugs in. Next job is replace battery box with reg/rec, starter solenoid and coils attached and try to start the beast!!! Some pix; Engine with all 4 plugs removed. ignition/alternator cover off to access 17mm crankshaft nut. Spinning motor with plugs out and car batter direct to starter motor. Short vid. Forgot I still aint got wiring loom etc.Double click on piccy.
You mean it looks that bad and doesn't run either!?! Do you fancy buying some magic beans.............?
