10- none abs blade planned mods opinions :D quite alot LOL
Discussion in 'Mods, Upgrades, Accessories and Products' started by gixerlc, Nov 15, 2011.
  1. Nutty Tart
    Nutty Tart Well-Known Member
    Jamie don't sweat it ... yur not overweight ... ya just need to be taller ... :D
  2. gixerlc
    gixerlc Active Member
    Jamie not bad that mate :D i just got my dads can eat anythin an not put weight on haha hence the lightness
    what you running on yours Nutty Tart? suspension wise
  3. Nutty Tart
    30mm Ohlins cartridges in the front with an Andreani piston kit ... and an Ex Gary Johnson Nitron race shock . (raced at the 08 IOM TT)
  4. BladeRR8
    BladeRR8 Active Member
    I remember that Ex Gary Johnson Nitron race shock on ebay you must have out bid me, LOL !!!!!!!!!!!
    Did it make a big improvement ? what kind of riding you been using it for ?
  5. JM1
    JM1 Active Member
    Consider the rev range as a % before you compare a Blade to a 675 (or any other trriple or twin). Triples and twins feel torquey at low revs because they don't rev very high, but a four has more torque in the same % of the rev range, it's just that that rev range is higher.
  6. Nutty Tart
    Soz .. but ya snooze ya loose .. :heh:
    Well blatting around the Kent countryside and track days . Yup a deffo improvement
    I jacked up the rear and the adjusters really make a noticeable difference when you fiddle with em
  7. gixerlc
    actually think we figured the problem out the throttle grip was spinning on the throttle tube ever so slightly and at a certain point with loose hands the throttle was shutting itself wasn't glued properly from new F**K sake lol
    roll on some renthals and some lockwire cant believe something so simple caused so much mayhem lol don't think I'll ever run a bike without lockwire on the grips even from new from now on lol
    an the 675 revs slightly higher than the blade :p
    can't wait to get the new and improved blade back together going to be some bike cant decide for the life of me what shock pretty sure its going to be k-tech forks :)
    Thanks,
    Tom
    can actually see the flat spot in the power on here :)
    #27 gixerlc, Nov 19, 2011
  8. JM1
    JM1 Active Member
    Proportions again though - comparing a smaller engine (675) to a larger engine (1000).
  9. BladeRR8
    Glad your enjoying it mate.
