Thankd fot thst info. The local bike shop said you can get a servo blanking plate from fleabay. Has any one heard of such a thing.
Well today I started removing old exhaust .I followed the manual and when it came to the servo wires on exhaust it said remove. I did this and one just snapped .Buggar, any way I continued and exhaust is all removed. I found the other end which just sits at back of engine on left side and just removed the cables by pulling them through outer cable and snipping at servo, so basically no cables attached at all but servo still in place. Will this be ok like this? I hope so as some of the replies on here have said remove servo cables which I have so fingers crossed..
I just unhooked the cables, the ends just slide out when the tension is taken off (you didn't need to snip them), and left the servo in place. Worked fine for me dude!
Thanks mate, that's piece of mind now. Can.t wait to try it as sounds awesome now. Hopefully sunday be dry enough for a blast.
